LS1 coil mounting
Old Nov 15, 2012 | 05:01 PM
studderin's Avatar
Default LS1 coil mounting
Anyone mount there coils only using one bolt each? I was going to cut down my stock brackets to just use the upper bolts, to the coils, and the bolts to the VC between them. (don't use the lower or rear ones anyway to the VC) Just to get them a little lighter, samller and easier to work on) And looking at my stock 2001 set and noticed the outer "frame" is not solid, like it has some interlocking fit or something. The LS2 and truck coils don't have this.
Are they still solid inside? Worried after some street driving could cause a problem with only 1 upper bolt in them hanging there. If they need 2 to support themselves? Not a exciting thread, but dont have spare coils to find this out.
Old Nov 15, 2012 | 08:03 PM
Paul Bell's Avatar
That's MISTER MODERATOR
I would think that the coils would vibrate at certain engine speeds.
Old Nov 16, 2012 | 08:55 AM
studderin's Avatar
ya, I just want want them to get damaged from it.
Is there any of the remote setups that only bolt them on one end?
Old Nov 16, 2012 | 09:09 AM
Neenjah's Avatar
I've seen them on a custom made bracket mounted up on the firewall with long plug wires. Cleaned up the valve covers significantly.
Old Nov 17, 2012 | 11:51 AM
studderin's Avatar
I want to keep them on the VC. It not just to be custom, or a show thing. Its about weight, and keeping the car simple to work on and not have issues with racing and street driving.
1 its fine for heat, and street driving, getting wet ect.
2 easy to work on, keeping them all bolted on the bracket only running 3 bolts into the VC and all 4 coils are off, and back on fast. You always have 10mm working on the car anyway.
3 Easy the remove and put the plug wires on, no change of mixing them up, and easy to fine a spare wire or get new ones fast at any parts store or a friend.
4 Same with the coils wiring, just one connector per side, on/off, fast and easy. No change to mix them up. Or non stock wiring to have problems.
Old Nov 17, 2012 | 09:02 PM
Snkebait95's Avatar
Since i swapped my ls into my 95 z28 im running the corvette fuel pressure regulator off of the fuel rail, so i have to use one bolt on that coil so i can turn it diagonal to clear the regulator. I decided to turn all of them diagonal to look good and theyre fine
Old Nov 18, 2012 | 04:58 PM
studderin's Avatar
cool,thanks man.
how many miles have you out on that? there the gen3 coils?
Old Nov 26, 2012 | 02:50 AM
AceBoogie's Avatar
it would probably get damaged.
Old Nov 27, 2012 | 04:07 PM
studderin's Avatar
you ever run one bolt, per coil?
