harmonic balancer w/o ac
Old Nov 17, 2012 | 05:04 PM
ldyzluvdis06's Avatar
Default harmonic balancer w/o ac
is there any company that makes a harmonic balancer/crank pulley without A/C? im thinking if they do it will be lighter, so i would prefer to go with it since i dont have a/c already
Old Nov 17, 2012 | 06:38 PM
03Sssnake's Avatar
ATI makes a great balancer and you can buy one without a provision for AC.
Old Nov 17, 2012 | 11:46 PM
badazz81z28's Avatar
I feel there would be nothing gained....put the cash elsewhere.
Old Nov 18, 2012 | 12:34 AM
agreed after seeing the price of the ATI one.
just going to order the powerbond one.
im assuming i would buy one for the ls since im using the ls accessories...? (swapped a lq4 in the car but need a new balancer)
Old Nov 18, 2012 | 08:56 AM
03Sssnake's Avatar
its not just about HP, ATI makes some of the best dampners out there. I have had nothing but issues with ASP, no experience with powerbond, though it appears to be the same heavy POS the ASP is. I spin my engine to 7K though, bad harmonics will eventually cause damage, broken timing chains etc..I only trust ATI.
Old Nov 18, 2012 | 09:21 AM
Ronny_02_WS6's Avatar
I got SLP Powerbond and feel super safe with the giant walls.
Old Nov 18, 2012 | 11:30 AM
bww3588's Avatar
These engines are internally balanced, the "balancer" is there to keep engine harmonics out of the accessory drive and drive them. If your chewing up timing chains, you have other issues.
Old Nov 18, 2012 | 05:20 PM
03Sssnake's Avatar
ASP balancers have been known to cause timing chain failures, that is well documented here...and yes I know they are internally balanced...bad harmonics can cause some serious issues down the road...why I will never cheap out on another dampner..
Old Nov 18, 2012 | 05:56 PM
bww3588's Avatar
Agreed. If the balancer is out of balance, it will transfer harmonics back into the rotating assembly. But a good balancer shouldn't.
Old Nov 18, 2012 | 06:55 PM
People have been running the stock damper on many applications. I agree w/BWW, if the damper is bad, its obvious there will be a side effect. As long as the thing is serviceable, shouldn't be an issue.
Old Nov 18, 2012 | 08:33 PM
decided to go ahead and pick up a SLP pulley. once it comes in within the next couple of days ill get this thing back on the road...pretty pumped!!
