Things to replace while swapping Intake Manifolds
Old Dec 15, 2012 | 02:46 AM
777Shock777's Avatar
Default Things to replace while swapping Intake Manifolds
Hey everyone, my next project will be to get a new intake manifold on my 99 T/A. - Still rockin the LS1 manifold.
I'll probably be going with a BBK or LS6 (if its real cheap), anyways..
I'm going to switch to the LS6 PCV system and completely redo that with a catch can.
Anything else I can replace while the manifold is off? - (I know the oil sending unit will most likely break)
Any parts/part #s would be appreciated. Since its winter I won't be driving it much, so there isn't a time restraint.
Old Dec 15, 2012 | 09:52 AM
sjsingle1's Avatar
knock sensors.........and harness
Old Dec 15, 2012 | 10:57 PM
GarrettM's Avatar
You shouldnt break the working unit if your carefull. Be sure to undo the vacuum line on the bsck of the manifold so it doesn't hand on the sending unit and you should be good to go. Ive pulled mine 8-10 time and never broke it. Just be carefull. Unless you want to replace it just for good measure....
Also if you buy a used ls6 mani swing by any auto parts store and get a new gasket kit for it. Only about $25 and is well worth it for peace of mind.
Old Dec 16, 2012 | 01:27 AM
Sweet, thanks for the input guys. I'll be sure to look up the parts on RockAuto and purchase em.
If I happen to see an LS6 manifold for real cheap I definitely will buy it, if not I'm gonna just stick to the BBK idea and p/p the stock TB. Hopefully its not too restrictive on the intake.
Old Dec 16, 2012 | 11:29 AM
mjs1012's Avatar
You can find ls6 manifolds for 325ish on here all day. Just gotta be quick when you see them.
+1 for a new gasket/pad kit. Well worth the 25$
Old Dec 16, 2012 | 03:39 PM
Yeah DEFINITELY getting new gaskets regardless of whether I buy new or used!!!
I'm pretty excited to get the PCV system and get some hp & tq out of this.
Plus peace of mind with replacing parts
Old Dec 16, 2012 | 06:30 PM
Firebirdmuscle's Avatar
I have a ls6 intake manifold for sale. If interested pm me.
Old Dec 16, 2012 | 09:49 PM
WS6_Veteran's Avatar
+1 on the knock sensors and harness. More than likely that motor bay has been cleaned before and more than likely water got under the intake. Guy on ebay sells acdelco with harness replacement for around $100. Great product and the trick is when you put the new ones on cover them in HIGH Temp RTV silicone.
This will keep the new ones from allowing any water down inside the knock sensor housing when you clean up that engine bay. Just pulled my intake a few months back because one of my knock sensors were bad (they were completely corroded) . It took me a good 3 hours start to finish, but now that I have a hang of it I think I could do it in about 2 hours if not less.
Old Dec 16, 2012 | 10:01 PM
djrowe007's Avatar
some people to frame ties, plugs and plug wires, new motor mounts, electronic cutouts, i have t tops, i want to get frame ties they also help with handling. I just got kooks headers and td's back.
Old Dec 16, 2012 | 10:32 PM
99Bluz28's Avatar
The key to not breaking off the OPSU is to remove the brake vacuum booster hose from the booster, then lift the intake up and move it forward.
Old Dec 17, 2012 | 12:55 AM
animerei's Avatar
Yes, I agree with your views and opinions
Old Dec 17, 2012 | 10:33 AM
djrowe007's Avatar
nevermind what I just said thought you were doing headers. lol
Old Dec 17, 2012 | 11:53 AM
I'll PM you shortly.
Sweet, thanks for the tip! - I'll be sure to replace those, I wont actually do this til about late Jan./Feb. to purchase all the stuff and have plenty of time to plan it out
Thanks man, I'll be sure to do just that!
haha, I'll keep those in mind when I tackle headers next in spring!
Old Dec 17, 2012 | 08:11 PM
sjsingle1's Avatar
the rubber intake gaskets get smushed and take that shape.............so NEW GASKETS ARE A MUST ..........the front TB gasket TOO !!!!
Old Dec 20, 2012 | 11:55 AM
I'm hoping RockAuto will have everything I need, I'd love to view everything in my cart and just go from there.
Old Dec 20, 2012 | 01:41 PM
Grimes's Avatar
dunno if you saw the trick used before, but you can also use tape near the bolt heads to hold up the intake manifold bolts past the mating surface when you are placing the intake onto the engine. remove the tape after the manifold is in position to drop the bolts down into the holes.
Old Dec 20, 2012 | 03:15 PM
WS.SIX's Avatar
Works well. I prefer using rubber bands though quicker for me.
Old Dec 21, 2012 | 05:04 AM
mjs1012's Avatar
I used 4 clothes pins to hold the bolts up and it was easy. A little trick....after you pop the hose off the booster pull it towards the passenger side of the engine bay around the back of the intake. This way there's less risk to breaking the opsu because the hose is the main cause of it breaking.
Old Dec 21, 2012 | 12:49 PM
I have not seen this before, anyone have a picture of this in action!?
Old Dec 21, 2012 | 02:27 PM
bmax's Avatar
Clothes pins FTW.
