Redoing my 2002 z28
Edit* I see alot of carb intakes is there any real advantage to going to a carb setup especially since my car is already fuel injected?
. I did find a couple dyno sheets from looking for info on google and most people that installed this did pick up some over an ls6 intake manifold. Like I said I bought it mainly because of the fact that I'll be running a direct port setup on my car and it already has the boss ports and the fact that is was half the price of a fast 92 setup. So even if it doesn't make as much power as the fast i'll be fine with it because i'll still have my nitrous. 98-02 LS1 FAST LSX Intake Port Seal Kit (Set of 8)
98-02 LS1 Nick Williams 92mm Throttle Body
98-02 LS1 FAST LSX Replacement Hardware Kit (Stainless Steel)
99-02 LS1 F-Body (Plastic) Racetronix Fuel System- Options: Battery Ground Kit & Pump Booste
93-02 Auto Meter Single Pillar Pod
Aem Digital Wideband Air / Fuel Gauge
98-02 LS1 FAST LSX Intake Manifold (92mm Inlet)
PRC Stage 2.5 5.3L CNC Ported Heads
Texas Speed & Performance 1-3/4" Long Tube Headers
Texas Speed Stainless Steel 3" Off-Road Y-pipe
Texas Speed Rumbler Cat-back Exhaust System -magnaflow tips
Texas Speed & Performance Chromemoly Pushrods
GM Replacement LS7 Lifters
Cometic LS1 MLS Head Gaskets
ARP Hex Head Bolt Kit, Pre-2004 Blocks
fuel injector clinic 42lb injectors
4.10 motive gear and rebuild of rearend
a little comparison picture between the fast 92 and a stock ls6 manifold.
I am trying to figure out, the fast intake manifold doesn't have a mounting prevision for this, does that mean it is not necessary?
Also if you hook 1/4 hose up to it say good bye to the coolant inside of your head bolt threads!
I got the first head on the car, it goes back so much quicker when you know what you are doing! I only had a couple bolts in on this picture but I've got it all torqued down now.
I did however get the last couple of parts that I was waiting for so that I can finish my car. I believe it will be a long monday night and a really long tuesday but I am going to try and have it 100% back together by tuesday....we'll see how well that works :p
Right now I have a ton of parts that are all ready to go on the car sitting in my office, and even more out in the garage :/
office shot
