Customizing CAI Fbody
This will be installed on my ws6 soon and should allow me to install a flat oval filter with straight tube. This creates a lot of room behind radiator, e ought I could stand in there. Would be great for turbo setup. I might create my own flat air box out of same material and seal off with hood to help with IATs at idle. Not sure yet, on the firebirds a filter shroud is probably not needed.
However, that is an incredibly simple set-up you have there.
Yes it is, didn't take much to put together.
). I asked him if he thought that worked better than a lid set-up, he said they gained a tenth from it. I started to text you a picture and tell you it was a bad turbo car I saw haha, since everyone always looked funny at me when they would ask how much power that crazy wheelie pulling turbo car made and I would tell them it was a nitrous car
That's not a turbo in the bumper???? Its "gotta be"
He started going on about how he though the reason was the air doesn't have to change direction as sharply (compared to when its brought from the bottom like a FTRA for instance) to make it to the TB. He says they plan to build some kind of dual inlet that matched the bumper so I pointed him to the Big Gulp thread.
I installed the inner fender since then so the heat from the tires wouldn't be as bad.
I also deleted the drivers side front corner cover so it can funnel as much air as it can.
This thing will never see rain and if it does it'll be engine off and snooze time lol
