Fuel Press Regulator
Old Mar 7, 2013 | 07:24 PM
Wikked00Hawk516's Avatar
Default Fuel Press Regulator
I just picked up a fast 102 with the fuel rail kit. For those that have one what do you suggest for a fuel pressure regulator since you can't use the factory one. Thanks
Old Mar 7, 2013 | 08:23 PM
jrpimp00's Avatar
WHy cant you use factory one? are you going FI, if not you can use it.
Old Mar 7, 2013 | 08:28 PM
The fast fuel rail kit doesn't have a regulator on it. You can't use the factory rails with the 102 intake. I don't see a way to remove the factory regulator. So I need to go aftermarket just looking to see what others are using and a pic of the setup
Old Mar 7, 2013 | 08:37 PM
jrpimp00's Avatar
F Body Regulator is in the tank, the rail has a damper in it. I dont have pics so I hope someone can show you a FAST setup, good luck
Old Mar 7, 2013 | 08:41 PM
LPE 403's Avatar
No FAST intake, but a MagnaFuel set up here. Picked up from Nate at Nasty...made my own mounting bracket fastened by one of the shock tower bolts.
Old Mar 7, 2013 | 08:51 PM
Thats right forgot it was in the tank. The rail one is a damper pressure equlizer. Thanks
Old Mar 9, 2013 | 12:44 PM
dailydriver's Avatar
That is one sick ITB setup!!
Old Mar 9, 2013 | 04:27 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Sick ITB? The whole damn thing is NASTY!!
Old Mar 9, 2013 | 07:59 PM
LPE 403's Avatar
Thanks guys
