Is my BBK now scrap...
Tore apart my motor to clean things up and to redo gaskets.. Found a lot of RTV gasket maker at rear of the motor.. Upon further inspection I see there is a piece of metal missing from the gasket support. Can this be fixed and be reliable?
I also noticed a bunch of oil in the intake.. is this from not using catch cans?
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Yeah, definitely looks like a port job gone bad. I'm not sure there's enough of a lip there to keep the gasket from popping inside when you torque it down, not allowing it to seal. If you do get it welded up, you'll probably still need to do a little grinding to shape and smooth that port. I'd definitely get it fixed, though. I definitely wouldn't trust that to seal.
It's a BBK intake, sorry for the bad pictures. It is the port that bolts against the head. The last thing I want is metal from a bad weld job or some rtv to go down into the cylinder. Thanks for the help so far.
