Whats the best replacement alternator????
Old Apr 30, 2013 | 11:56 AM
97camaro383's Avatar
Default Whats the best replacement alternator????
Im looking to replace my alternator but wan't sure if I should just pick up a replacement at Autozone or one in the classifieds? Are there any better alternators?
Old Apr 30, 2013 | 09:26 PM
gMAG's Avatar
I went through Hite Parts Exchange. No core/good price.
Several years ago, I bought directly from their outlet. Now, I see that they deal through Ebay.
Old May 1, 2013 | 12:06 AM
evldoer's Avatar
I just got a NEW, not rebuilt A C delco alt. from rock auto for 139$ plus shipping. By far the best deal for a new f body alternator that I could find.
Old May 1, 2013 | 12:45 AM
sjsingle1's Avatar
WHAT?? ...........not A word about the truck alt upgrade??? fer shame fer shame.......
Old May 1, 2013 | 01:36 AM
Blk98Vert's Avatar
Yep, truck alternator
Old May 1, 2013 | 11:21 AM
Are the truck alternators a direct swap? No fitment issues and do they have more amps?
Old May 1, 2013 | 02:51 PM
dailydriver's Avatar
WHICH truck alternator (actual part # please), and are they available in Delco/Delphi through Rock Auto as well???
Old May 1, 2013 | 06:49 PM
redbird555's Avatar
The part number is going to change depending on brand. Just go to any local parts place or rockauto for acdelco and lookup the alt for an 01-04 denali or escalade with the 145amp option and you'll find it. I'm running a rebuilt from autozone now and it's great direct bolt in
Old May 1, 2013 | 06:57 PM
sick_tight's Avatar
truck alternator here as well. I don't remember the part but there is a thread on here about it. I think the title was alternator fix or something of the sort
Old May 1, 2013 | 07:46 PM
sjsingle1's Avatar
https://ls1tech.com/forums/generatio...-failures.html
stikees are your friend
Old May 1, 2013 | 10:28 PM
trans_am7935's Avatar
this is the best upgrade i ever did (almost, cam is best), even at idle my stereo does not dim the lights any more.
Old May 3, 2013 | 04:00 PM
gMAG's Avatar
Here's another...145 amp/Brand New/ 100% Positive Feedback/Free Shipping/$109.80
http://www.ebay.com/itm/Alternator-LS1-CHEVROLET-Camaro-Trans-AM-145-HIGH-AMP-1998-1999-2000-2001-02-5-7-/130892934574?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1998%7CModel%3AFirebird&hash=item1e79d3adae&vxp=mtr
Old May 4, 2013 | 06:32 AM
Gray86hatch's Avatar
Try and find a local alt shop that can repair the one you have.
The shop I use repairs are normally about 70% less than a new parts store piece.
Tim
Old May 10, 2013 | 01:55 PM
Dal1as's Avatar
The general part number that is used is "AD244" with the 4 wire connector.
I got one for my engine rebuild because my old alternator wasn't up to par. Have tried rebuilt and high power alternators and they all pretty much sucked. Hopefull the truck alternator will do better.
Old May 14, 2019 | 11:43 AM
lleonflo's Avatar
Found the ACDelco PN if anyone is looking for this "upgrade" #321-2128, as stated above it's listed for a 03-04 escalade and has an rpo code of KG3. With the 4 pin connector. Cheapest I've seen so far is $250 from summit.
Old May 15, 2019 | 02:40 AM
sjsingle1's Avatar
old thread dig !
I believe that P/N is for a reman alt......
Old Jul 13, 2020 | 11:27 AM
jybravo70's Avatar
Veteran: Navy
Sorry to revive an ancient thread, I found on the AutoZone site the following and wanted to confirm (used the quoted P/N and RPO for the 145-AMP version).
https://www.autozone.com/batteries-s...21881_552733_0
This online calculator (apexcustoms.com/car-audio-calculators) is outputting 62.5 Amp required on 14.4v DC draw (peak?) just for amps, not head unit and usual car consumption needs (ECU, AC, Lights, etc.) which is over the stock 102 Amps and 12v DC alternator.
Looking at this the "Truck" alternator is adding 43 Amps above the stock (for a total of 145 Amps), not sure this would be able to absorb the 62 Amps?
The current, 7/13/2020 Autozone price is $414, the high outputs I found Texas Speed and Performance has a 240 Amp alternator (#159-8206240) and priced at $350 specifically for LS1 applications and the 2002 Trans Am is listed as a vehicle it will fit (they also have 270 Amp and 370 Amp models). This is a 100 Amp increase for $150 less!
I found PurePower makes a 250 Amp alternator
(250AMP PurePower Hairpin High Output Alternator Chevrolet GMC Trucks 1996-2016), currently on sale for $300 at Phoenix Alternators.
The one thing I don't like on the PurePower is it seems to not "kick-on" until >1,000 rpm, the Texas Speed "kicks-on" at 850 rpm. Would this mean at idle all the power is draining the battery with PurePower? Both have the 4 pin rectangular plug.
The Texas Speed alternators are listed as for racing only and not street, not sure if this will be a problem???
Old Jul 13, 2020 | 11:42 AM
Dragframe's Avatar
Best is gunna be a bad boy Mechman
