Torquing head bolts ???
EXCEPT when the consumer has to do any work on the engine gm says you gotta jump through a few hoops......
believe what you want.
the avg joe with a torque wrench cant torque them all at the same time and therefore must use the angle method to ensure each bolt is stretched to provide accurate clamping power.
have you ever pulled an old TTY bolt out and compared it to a new one? You can visibly see that its a little longer after its one torque pass. Believe what you want and have fun pulling broken tty bolts out
