Questions about LQ4 build
Hey guys, I'm new to this forum and I had a few questions about a turbo build I was planning. Any and all input is much appreciated, as I am also new to the LS world in general. My first question is regarding flywheels, in order to make my transmission (ford tko) to work with an LQ4 I need a 168t flywheel, is there any manufacturer of that flywheel for these engines, I've searched a little and none of the sites list an LQ4 as an application. My second question is can I use an LS1 harness for this motor in my fox body swap? If it matters I've done a little research and had planned to swap over many LS parts on to this motor. My last question is what kind of power can a stock one of these hold with fastener modifications is ARP bolts/studs where needed etc? Thank you, and once again any info you guys could give me is greatly appreciated.
LCpl Mike C USMC
LQ4Fox
LCpl Mike C USMC
LQ4Fox
As long as the LQ4 is 2002 and newer, it uses all the same bolt ons as an LS1... its the same design, just iron block an 4" bore. You can use any harness you want, as its all the same. If you have an older LQ4 with iron heads, it rear crank snout is longer and wont work with certain transmissions.
OK thanks that helps a lot actually, I had been looking at an 01 lq4 but now I'll start looking for 02+ any I do you could give me on what the power limit is for stock short block lq4's? I keep getting mixed answers.
LCpl Mike C USMC
LQ4Fox
LCpl Mike C USMC
LQ4Fox
Actually, 01 and up you'll be good. HP depends on a lot of things... how the engine has been taken care of is a major factor that you wont really know. My LQ4 with BBK longtubes and an LS6 intake, otherwise bone stock with 113k miles, got me a 12.83 at 108 last week, and that was on a fat 11.9 AFR and a slow shifting stock 60E. Not bad for a heavy old truck motor... they're DAMN good engines. I wouldn't be scared to put down 500rwhp with it, but that's just me. I try not to take it above 6000 and my cam choice will reflect that... Id like it to last for a while so I can have some fun this season!
Well as it goes I found a bare block that has 100k on it for 100 bucks, so I figure I'll just build it from the ground up, I'd like to get 800-850 at the tire with twin 76mm turbos on conservative tune, I also figure that since I'll be running a manual tranny it should be a bit easier to get those numbers. I had another questionabout cranks/rotating assembly, can I just get a fully forged LS1 assembly and drop it in this block? The block is an 05 by the way
I have been looking at rotating assemblies and for about 3 grand I can get a 1500hp capable 418 stroker kit, so I was thinking of doing that with either twin 76's or a single 88. I do appreciate all the info you guys have given me, are there any tips I should know or any suggestions you guys may have for this build? Its my first one so I'd like to do it right, and I know you guys all know your stuff
Haha thanks, I expect it to be interesting to say the least, first Chevy build and its going in a fox mustang lol. Can't wait for the headaches haha, but thanks again for the info, now I've got some type of structure for this build.
