Can these heads be ran as is?
Old Sep 20, 2013 | 11:12 AM
Decadence75's Avatar
Default Can these heads be ran as is?
Hey everyone. I recently picked up a set of 243 heads off e-bay for a great price. The only issues were a broken header bolt and some light damage to one of the intake ports. Do you think that these are ok to run as they sit? The damage looks like it is inside of the gasket area so I don't believe that proper sealing would be a problem. I eventually plan on sending these off to AI for the 226 program but that is at least a year, probably 2 away. I would rather make some use of them now if I can rather than have them sitting on a shelf for a couple years. Thanks in advance.
Old Sep 20, 2013 | 12:53 PM
ws6man29's Avatar
So you were the guy who recently bought them off ebay? I would have them looked at by a shop before slapping them on. You will need to redeck them before slapping them in. Good luck man!
Old Sep 20, 2013 | 01:10 PM
What do you mean, "So you were the guy who recently bought them off ebay?"
Old Sep 20, 2013 | 01:13 PM
thunderstruck507's Avatar
seems to be fairly well inside the sealing ring...if it were me and I were in a pinch I would probably give them a go with brand new intake gaskets after a light surface job on the engine side of the heads
if it does leak there, pulling the intake and applying some RTV would be a hassle but take care of the issue IMO
Old Sep 20, 2013 | 01:23 PM
ws6man29's Avatar
I seen them on ebay with the same issues and was wanting to know if you were the guy who bought them recently
Old Sep 20, 2013 | 01:33 PM
Ahhh, ok. It looks like I am not the only one. There is someone in the internal section asking about a skull stamp on the heads and he apparently got them from the same place I did. They usually have several sets up on auction with minor defects and give a pretty good price on them.
Old Sep 20, 2013 | 01:36 PM
Awesome. I just wanted to make sure there weren't going to be any major issues if used with the damage. like that. I'm sure when they get ported that will be taken care of. Just gotta save up the scratch to send them off.
Old Sep 20, 2013 | 02:20 PM
ws6man29's Avatar
What did you end up paying?
Old Sep 20, 2013 | 02:22 PM
$285 + $27.10 shipping
Old Sep 20, 2013 | 02:59 PM
are they sodium valves?
this site isn't a terrible place for deals...I got my 799s from the classifieds for $240 shipped because one had some minor chamber dings from a busted piston and a bent valve
I lapped in a valve from my old heads and did some hand cleanup along with a .010" surface job and they were good as new
Old Sep 20, 2013 | 03:05 PM
s14kouki's Avatar
I would just have a shop go over them.
Old Sep 20, 2013 | 03:08 PM
No, no sodium valves unfortunately. They came off a 5.3 motor. This is usually my go to place for trying to find a deal on parts. However everyone was wanting around 400 - 450 + 50 or more for shipping at the time. When I found these it was just too good to pass up.
Old Sep 20, 2013 | 09:19 PM
xxtremes33's Avatar
a manifold should seal to the heads fine. i would use them. i would clean up any high points first though
