Speed Engineering Race Version Headers Now Available!!
Nilla: I doubt it. The F-Body driver side collector kicks out pretty far. They hit the frames of most trucks.
Mavn: Thank you for your order. Tracking should be updated to you via email/invoice, or eBay depending where you purchased from.
Dabom75: Not sure if GMMG exhaust works. I would assume so. You can always cut off the tip of the Y-Pipe making it 3".
Thanks
Sean
The car has brand new motor mounts however if I had sagging mounts I almost bet the install would be better. As I said when I emailed you. My phone died that night or I'd have pictures. I'll have the car back in the air tonight.
Attachment 461595
Attachment 461596
Attachment 461597
Attachment 461598
Dave
Attachment 461595
Attachment 461596
Attachment 461597
Attachment 461598
Look good Im about to order!!!! And ditching my rusty pacesetters.
I received my headers and they look pretty good.
It really helped more for the Motor Mount Install more than the headers and Y pipe. Some steps weren't necessary for me as well but most of it was spot on.
I have two questions as well:
1. I couldn't get the stock cross member(Tunnel Brace) back under the Y pipe. What are you guys using to remedy this? Stock member with longer bolts and a spacer or is there something else I can do?
2. My drivers side is banging some I think I might be able to tweak the two bits of the Y to angle it down and away some. But if its the header pointing up how are you guys bending it down a little?
Thanks
