Speed Engineering Race Version Headers Now Available!!
Old Jan 21, 2020 | 11:36 AM
  #1361
Spamfritter's Avatar
I just installed my headers last night. The passenger side was pretty easy, but the driver side sucked. I ended up pulling the spark plugs and the steering shaft to get the necessary clearance to get the header on that side. Fit and finish are pretty good, welds seem nice. I'm really surprised how good these headers are built and how good they look for the money. They seem like they'd be much more expensive. Now that I need an exhaust setup, I will put their exhaust on my short list of considerations.
Old Jan 21, 2020 | 10:48 PM
  #1362
wannafbody's Avatar
[QUOTE=SarGntoperez;20198367]It sucks that speed engineering doesn't sell or ship headers to California[/QUOTE
Sorry you live in a sucky state.
Old Jan 21, 2020 | 10:52 PM
  #1363
SarGntoperez's Avatar
[QUOTE=wannafbody;20199445]
tell me bout it
Old Jan 21, 2020 | 10:53 PM
  #1364
Not even for pre-'75 vehicles? No restriction on them.
Old Jan 21, 2020 | 10:54 PM
  #1365
75 and under no smog needed
Old Jan 21, 2020 | 10:55 PM
  #1366
Right. That's what I said. No restriction against headers for them.
Old Jan 21, 2020 | 10:59 PM
  #1367
California really sucks tho can't really do **** to my car
Old Jan 21, 2020 | 11:02 PM
  #1368
What do you have?
Old Jan 21, 2020 | 11:04 PM
  #1369
What do you have?
02 ws6 6 speed, mods are gmmg, slp y pipe, slp lid and bellows and a ported throttle body
Old Jan 21, 2020 | 11:15 PM
  #1370
All that will pass smog, because they don't show or are CARB approved. No long tubes will pass smog, main reason being the cats would have to move back, and that is forbidden more than a few inches. So even if they shipped into CA you wouldn't be able to run them and pass smog.
Old Jan 21, 2020 | 11:42 PM
  #1371
Back then my plans where to install a Howard's ASA cam with tsp stage 1 ls6 heads, tsp 1 7/8 with tsp ory but i don't want to have trouble passing smog or finding a place that will do it
Old Jan 22, 2020 | 12:29 AM
  #1372
No cheating anymore, though it is simplified now.
Visual for all required equipment (cats, mainly, in original location) and plugging into OBDII connector to check for codes.
If the internal mod (like a mild cam) doesn't set a code, you're good!
The scanner is connected to the central CARB computer, so bribing the tester WILL be fruitless.
So what CAN you do? Any head porting or valve job, CARB-exempt air intake, cat-back exhaust, mild cam, and tuning.
As long as OBDII doesn't throw a code, you're good there.
Old Jan 22, 2020 | 01:05 AM
  #1373
For that reason is why I wanna use tha lpe gt2-3 cam poeple say you can't even tell there's an aftermarket cam in there, plus I'll be using some 799 heads, ima keep my ls6 intake, plus shorty jba dynomax ory no cats and when is time for smog I'll just swap back the stock cats with the slp y pipe. I think I should be good for smog with those mods plus cam and heads cause I'll be tuning it anyway
Old Jan 24, 2020 | 01:13 PM
  #1374
I got my headers installed in my 2001 Camaro SS over the weekend. The install was super easy given that the car doesn't have the intake or allot of the wiring in it right now. But, the driver side sucked to install. The main issue is that it ran into clearance issues against the steering linkage. So, I removed it and installed the headers and then put the linkage back in. That was the worst of it. Otherwise, this was fairly easy and relatively straight forward.
Old Jul 11, 2020 | 09:15 PM
  #1375
Stephen Nix's Avatar
What exhaust system you running? Or you added the speed engineering headers to the stock exhaust system?
