Speed Engineering Race Version Headers Now Available!!
Old Jul 29, 2014 | 11:27 PM
  #581
RGSS's Avatar
Just ordered a 1 3/4 set with y pipe.
Looking forward to the install.
Old Jul 30, 2014 | 09:32 AM
  #582
blacktransam's Avatar
Originally Posted by Speed Engineering
I never said anything about having the factory make any changes. I was joking in saying the closest spot I can even find is the K-Member on the drivers side, but also stating there was 3/4" of clearance. The tube was no where close to the K-Member.
Honestly, this is extremely frustrating. If your having that many issues please return them, and I will give you a full refund. If anyone else is having issues besides the tip of the collector angle please contact me. I think the most frustrating part is that we have sold over 300 sets of these with all but one singe return for fitment, which were sent back to the customer to use again. That has to say something about the quality control of these headers.
Sean
Never said anything about having the factory make a change? third paragraph down of this post.
https://ls1tech.com/forums/18247630-post402.html
Frustrating for you? You didn't have to install them. And 300 set's sold? i was a pre order and had them installed with in 2 days of recieving them. Maybe most aren't installed yet? Time will tell as others post, maybe i got a **** set? anythings possible. As i said i'm making them work, if you get a fixed drivers side, i'd love to try one.
Old Jul 30, 2014 | 11:38 AM
  #583
Speed Engineering's Avatar
Sponsor
RGSS: Thank you for your order. They will go out today.
blacktransam: I thought you were referencing the K-Member. The collectors have always been that way. Like I was saying before we never saw any issues with the collector for a long time after we started selling these, and have still only seen the issue on a few cars. Its never been a concern to us until recently. With that being said we only moved the tip of the collector down around 3/8", it still wont compensate for vehicles with tweaked chassis/larger motor mounts etc. For most of the vehicles there should be more than enough clearance however.
Thanks
Sean
Old Aug 3, 2014 | 03:17 PM
  #584
Pharcyde50's Avatar
Do you have the 1 7/8 in stock? May order some tomorrow?
Old Aug 3, 2014 | 05:17 PM
  #585
Sponsor
Yes, sir. Sounds good.
Thanks
Sean
Old Aug 4, 2014 | 08:49 AM
  #586
blitzace12's Avatar
I am looking for a catted system. Will the 7/8 mate up to a TSP catted y pipe?
Old Aug 4, 2014 | 11:20 AM
  #587
Sponsor
They should connect just fine. We have never tried it here, but a few customers said they worked.
Thanks
Sean
Old Aug 4, 2014 | 01:28 PM
  #588
Fry_'s Avatar
I'd rather add Magnaflow cat's to a ORY that way I know the quality of the cats being used. Maybe I'm just paranoid after seeing a friends Jet Hot cat that was completely hollow after less than 5k miles, but I wouldn't want to use no name chinese cats.
Old Aug 4, 2014 | 08:31 PM
  #589
mikh338's Avatar
So you guys have revised the driver collector and moved it down 3/8"?
Old Aug 5, 2014 | 11:07 AM
  #590
Sponsor
Nope, we plan to adjust it straight on future batches, but it still wont solve the issue some have with chassis clearance. Its a common issue with most aftermarket longtube headers and the F-Bodies. We have heard of a handful of guys that have the issue. It is usually due to a mildly tweaked chassis or different motor/trans mounts etc. I believe Mufflex even makes a bracket specifically for the issue. Unfortunately, we cannot drop the longtubes any more than they are for the lowered guys. Found the link to the Mufflex kit:
http://www.mufflex-performance.com/9...pter/61-y.html
Thanks
Sean
Old Aug 5, 2014 | 11:12 AM
  #591
demonspeed's Avatar
It's not mine! woo hoo!
I think most people find the banging or hitting to be a non-issue once new engine mounts are installed.
Old Aug 5, 2014 | 01:42 PM
  #592
The Alchemist's Avatar
UNDER PRESSURE MOD
Are you guys coming to LS FEST, if so, any plans to bring a set of 1 7/8 race version with ypipe?
Old Aug 5, 2014 | 03:55 PM
  #593
mikh338's Avatar
I currently have stock stand and clamshells with poly mounts, chassis is perfect so im hoping i wont have an issue, i would have ordered these already
Old Aug 5, 2014 | 04:22 PM
  #594
Sponsor
mikh338: Nice talking with you. If you have any other questions just let me know.
The Alchemist: Nope, looks like a fun event though. Unfortunately, it would be a 31 hour drive for us.
Sean
Old Aug 6, 2014 | 08:35 AM
  #595
thunderstruck507's Avatar
Some of you guys would **** if you saw what I had to do to make my Doug's Chevelle LS swap headers fit. And they were over $600 and ceramic coated so now they look like ****.
I might try to get some of these 1 7/8" and heat and flex them to fit my car at some point.
Old Aug 6, 2014 | 11:56 AM
  #596
Pharcyde50's Avatar
Ordered my 1 7/8. Then I'm going cut them up and add Cone Engineering DIY Merge collectors with a spike. Should be interesting pics to come
Old Aug 6, 2014 | 12:27 PM
  #597
Ernie W's Avatar
I was wondering if someone could help me out on this. I'm trying to figure out the length of the headers from top to bottom for ground clearance in a swap application.
I'm looking for the 1-7/8" longtubes, I did a quick sketch in MS paint. I hope it uploads. Looking for length from top to bottom as shown with the blue line.
Thanks
Old Aug 6, 2014 | 12:49 PM
  #598
Sponsor
Here you go. This is the drivers side header specs. Passenger side is about 1/2" less.
Thanks
Sean
Attached Thumbnails Speed Engineering Race Version Headers Now Available!!-headers1.jpg
Old Aug 6, 2014 | 01:21 PM
  #599
Ernie W's Avatar
Thanks
Sean
Thank you very much, right around what I was hoping for. I'm pretty sure they won't hang down much below the subframe on my 2nd gen Firebird. I'll more than likely be ordering a set soon.
Old Aug 7, 2014 | 10:47 AM
  #600
Sponsor
Sounds good.
Thanks
Sean
