Speed Engineering Race Version Headers Now Available!!
Old Aug 17, 2014 | 08:13 PM
  #621
demonspeed's Avatar
It's not mine! woo hoo!
Originally Posted by paradigmGT
Guys I am not able to fit the stock bracket that supports the stock y pipe onto the new speed engineering y pipe. Has anyone else run into this problem?
Yes -- the stock bracket does not work with any y-pipe
Old Aug 17, 2014 | 08:51 PM
  #622
GuardianMagnuSS's Avatar
Someone brought this up and Sean reiterated. If you want some sort of support for the Y pipe, mine feels pretty sturdy but that added reassurance is nice http://www.mufflex-performance.com/9...pter/61-y.html
Old Aug 17, 2014 | 10:44 PM
  #623
paradigmGT's Avatar
I managed to re-use the stock bracket but only with one bolt on each end and have it positioned on an angle just to support the ypipe for now. I am going to go with the mufflex type or get hangers welded. I do not feel comfortable having all of that weight being supported by the engine block.
Old Aug 18, 2014 | 01:39 AM
  #624
I feel ya.
I couldn't use one of the supplied clamps on the Y to catback section and we just threw a U clamp on for the time being. It was kinda unstable but stupid us in a rush could of used the stock clamp.
Slapped that on with the other clamp still on and it tightened up a lot more.
Maybe if you wanna add another clamp on that spot for some more support it helped a lot for me. An impact gun helped a ton too!
Old Aug 18, 2014 | 08:34 AM
  #625
demonspeed's Avatar
Just remember it's also being supported from the hanger on the over-axle pipe. The SE y-pipe also weighs much less than the OE setup with cats. Also, the Mufflex hanger was intended to help with banging, not support. So long as one upgrades to poly mounts then it's not necessary for anything more than peace of mind.
Just some food for thought
Old Aug 18, 2014 | 09:19 AM
  #626
Originally Posted by demonspeed
Just remember it's also being supported from the hanger on the over-axle pipe. The SE y-pipe also weighs much less than the OE setup with cats. Also, the Mufflex hanger was intended to help with banging, not support. So long as one upgrades to poly mounts then it's not necessary for anything more than peace of mind. Just some food for thought
ahhh just read the description for that. Good to know
Old Aug 18, 2014 | 10:54 AM
  #627
Speed Engineering's Avatar
Sponsor
Thanks for answering all the questions guys..
Sean
Old Aug 19, 2014 | 09:31 AM
  #628
ddnspider's Avatar
Originally Posted by Speed Engineering
Thank you for your order!
Sean
How long does it normally take for the headers to ship once the order is placed? Ordered mine last Friday and I thought these were in stock. Thanks.
Old Aug 19, 2014 | 11:00 AM
  #629
Sponsor
Orders ship the same day or next business day. Both 1 3/4" & 1 7/8" are in stock. I believe you sent us an email this morning we answered as well.
Thanks
Sean
Old Aug 19, 2014 | 11:38 AM
  #630
ddnspider's Avatar
Thanks
Sean
Yup, we're good. Thanks for the quick response and explanation.
Old Aug 19, 2014 | 11:54 AM
  #631
Pharcyde50's Avatar
Got my 1 7/8 installed great design and fit easily. I cut off the collectors and welded in some velocity spikes and a merge collector. So now I have a badass set of headers for under $400.
Old Aug 19, 2014 | 12:07 PM
  #632
ragtopz28's Avatar
Any pics?....still waiting on mine (due to y-pipe back order)
Old Aug 21, 2014 | 11:29 AM
  #633
Cstone812's Avatar
I'm just going to run some bullet mufflers with turndowns off the collectors I hope I don't have as much trouble with the driver side clearance as i am hearing about.
Old Aug 21, 2014 | 11:37 AM
  #634
ragtopz28's Avatar
"Isn't it a bit loud?"...WHAT? I CAN'T HEAR YOU
Old Aug 21, 2014 | 03:11 PM
  #635
Cstone812's Avatar
Because racecar lol
Old Aug 21, 2014 | 04:17 PM
  #636
ragtopz28's Avatar
Because racecar lol
That's cool.... My old race car had headers with only 18" extension pipe @3.5". Try this...face your 'turn downs' at 45 degree towards each other. It sounds cool and blows oil (somewhat) toward center of car ( in the event of a "let-go") instead of on the tires.
Old Aug 21, 2014 | 05:30 PM
  #637
cali_bear2003's Avatar
The bracket just did not bolt up, but fit like a glove to my catted arh u-pipe. I did however pay dearly for the fit..
Old Aug 22, 2014 | 09:26 PM
  #638
slpspeeed's Avatar
I dont know why everyone else is having issues. Mine bolted right up. Had to jack the engine up on one side but they look amazing and sound phenomenal. Where else can you get a set of quality headers like this for cheap? Nowhere
Old Aug 23, 2014 | 07:56 AM
  #639
The Alchemist's Avatar
UNDER PRESSURE MOD
So the ypipe is still not available?
Old Aug 23, 2014 | 10:54 AM
  #640
Cstone812's Avatar
Finally got mine on. Passenger side went on perfect driver side however was a different story. The header wouldn't even fit without shaving off some of the bellhousing on my trans and then I had to hammer it up with a piece of wood and a hammer.
