Speed Engineering Race Version Headers Now Available!!
Old Aug 11, 2014 | 06:14 PM
  #601
TransAmWS.6's Avatar
I was skeptical at first, but I got the SE 1 3/4 inch race headers and off road Y installed today, these headers have excellent fitment. Car put down 351rwhp/365rwtq with the converter locked after the tune, everything else stock other than a lid.
Only problem was that the Y pipe was touching the floorboard in one spot over by the drivers side headers, but that was dealt with fairly easily with a little modification to the Y. Definitely would recommend these to others.
Old Aug 11, 2014 | 06:56 PM
  #602
Speed Engineering's Avatar
Sponsor
Thank you for the comments and business..
Sean
Old Aug 11, 2014 | 08:35 PM
  #603
GuardianMagnuSS's Avatar
How did you take care of this? Its my only problem as well.
I used exhaust wrap for now to stop it from tapping too loud but its still there.
Old Aug 11, 2014 | 08:56 PM
  #604
I didn't do it but I ended up having the portion of the Y that was hitting flattened down a little. Then it was welded to the drivers side header so it would be flush and wouldn't leak. So, the drivers side section of the Y pipe and drivers side header are now one piece, costed me like $80.
This makes the headers more difficult to take out, but nothing on my car was banged on or notched so I'm fine with it.
Old Aug 12, 2014 | 08:14 AM
  #605
I didn't do it but I ended up having the portion of the Y that was hitting flattened down a little. Then it was welded to the drivers side header so it would be flush and wouldn't leak. So, the drivers side section of the Y pipe and drivers side header are now one piece, costed me like $80. This makes the headers more difficult to take out, but nothing on my car was banged on or notched so I'm fine with it.
Nice thanks bud!!! I was gonna get most of it welded cuz they leak some so I'll look into flattening that section too. I'm not bashing on my car that's for sure
Old Aug 12, 2014 | 04:39 PM
  #606
Sponsor
Not sure if you saw the link on the other page, but you have this option as well. Mufflex makes a kit:
http://www.mufflex-performance.com/9...pter/61-y.html
Thanks
Sean
Old Aug 12, 2014 | 05:06 PM
  #607
Originally Posted by Speed Engineering
Not sure if you saw the link on the other page, but you have this option as well. Mufflex makes a kit: http://www.mufflex-performance.com/9...pter/61-y.html Thanks Sean
Thanks Sean think I saw that in passing and forgot about it.
Problem is my Y section under the drivers side is about an 1/8" apart from one another.
Unless this alleviates that too. I'll look into it.
Unfortunately when i installed the Y pipe my rear sway bar was hitting my cutout and it gave us a false clearance. In the air there was an inch or more but on the ground it was touching the floorboard.
I need to pull the catback again and see if I can twist those sections for more clearance. With the cutout off I will have an idea of what's really going on
Thanks again
Old Aug 15, 2014 | 10:39 AM
  #608
ddnspider's Avatar
Just ordered your 1 7/8 headers off fleabay. Hopefully theyll let my 383 breath. now that Im going back NA.
Old Aug 15, 2014 | 11:22 AM
  #609
Majestic9C1's Avatar
anybody have installed pics yet???
Old Aug 15, 2014 | 11:36 AM
  #610
Sponsor
Thank you for your order!
Sean
Old Aug 15, 2014 | 12:34 PM
  #611
ddnspider's Avatar
I'm hoping within a couple of weeks. Interested to see what the clearance is like with such large primaries.
Sean
No problem, looks like a good product. Hopeful the clearance is good and hopefully what you guys say about Pacesetter 3" Y pipe fitting is true cause I bought one lol.
Old Aug 15, 2014 | 02:30 PM
  #612
paradigmGT's Avatar
When installing the headers and matching y pipe, which gaskets will I need to purchase extra other than the actual exhaust manifold gaskets? Is there a flange between the long tubes and the ypipe that requires a gasket? What about between the y pipe and the catback, is a gasket needed there? Does the speedengineering package come with the required gaskets for these points?
I am hoping of doing the install tomorrow.
Am I dreaming when thinking this will take around 6 hours as a first timer on a stock car, or should I expect it to take way longer?
Old Aug 16, 2014 | 11:38 AM
  #613
Originally Posted by paradigmGT
When installing the headers and matching y pipe, which gaskets will I need to purchase extra other than the actual exhaust manifold gaskets? Is there a flange between the long tubes and the ypipe that requires a gasket? What about between the y pipe and the catback, is a gasket needed there? Does the speedengineering package come with the required gaskets for these points? I am hoping of doing the install tomorrow. Am I dreaming when thinking this will take around 6 hours as a first timer on a stock car, or should I expect it to take way longer?
You just need new header gaskets, GM or whatever you'd like. No other gaskets are needed.
Took me and a couple friends about 10 hours but the install included motor and tranny mounts, plugs and wires. Plus some trouble shooting at the end.
Just the headers and Y maybe could do in 6 hours, everyone's car is a little different. GL
Old Aug 16, 2014 | 05:07 PM
  #614
paradigmGT's Avatar
Any tips on how the hell to access the farthest back exhaust manifold bolt to remove it, especially on the passenger side? I cannot see to get it it.
Old Aug 16, 2014 | 06:05 PM
  #615
ddnspider's Avatar
1/4 ratchet is your friend. Need to pull the number 8 coil pack makes it easier too
Old Aug 16, 2014 | 11:58 PM
  #616
Swivel attachments too
Old Aug 17, 2014 | 02:47 PM
  #617
paradigmGT's Avatar
I noticed there is no o2 bungs on the y pipe... what to do with the rear o2 sensors?
Old Aug 17, 2014 | 02:50 PM
  #618
SDyess's Avatar
You have them tuned out or deleted.
Old Aug 17, 2014 | 04:06 PM
  #619
youre only running the front 02s. Front and rear are needed for Catted, before and after.
Get em tuned or deleted like said. With Off Road Y pipe you only use the fronts.
You need longer 02s(rear vette), extensions or swap pins in PCM(if you're up for a little different approach).
Old Aug 17, 2014 | 04:40 PM
  #620
paradigmGT's Avatar
Guys I am not able to fit the stock bracket that supports the stock y pipe onto the new speed engineering y pipe. Has anyone else run into this problem?
