Pfadt Tri-Y Headers
I'll get under there and play around in a bit. I hope I don't have to drop it, but if I do I do.
Let me be the first to say, holy hell. What a job that was. 2 floor jacks, one supporting the motor and one literally holding the subframe. I think we dropped the subframe a total of 10" at one point.
You WILL need to remove the grounds on either side of the block, as well as the starter wires. Even then it's still right and the stars have to align to get them in. But... They're in.
Problem is, Phadt manufactures the nicest set of headers one can order for the C5 imho - short of maybe having a guy like turbojoe custom weld something up, which would obviously be a little ridiculous for a NA application.
Excited to see what she looks like all buttoned up. Doing anything else while you have her in pieces?
I'll try to get some pics up in the morning, bit before I install the X and after.
Nothing else planned right now. Gotta get all the bolt-ons done for the time being. Then, my wife has been patiently waiting for a few things so that has to come first before I delve any deeper into this.
about to get a LOT throatier....you'll enjoy making it bark on command of the
loud pedal...LOL....Also those GS wheels look real sinister for sure....
Brought the upper control arms back up and bolted in, and bolted down the bottom of the front shocks. Cleaned the heads. Got new intake manifold gaskets, and the plugs / wires should be here today from Aaron @ Texas Speed (Awesome service!!)
Heads aren't "perfect" but that's all I'm doing till I pull em off.
Found out the O2 extensions I have won't work. 04 uses a square plug, and not a straight inline plug.
Pfadt was awesome about it though and offered to overnight them to me. I opted to just use the rears as the fronts. Gonna swap a few PCM pins tomorrow.
Here's a quick teaser shot of the passenger side. Only one bolt holding it in for now...
Video Link: http://www.youtube.com/watch?v=zx2huqEkcGwI'm unsure what I have though. Either the Touring, Sport, or Pace Cars.
Apparently the only way to know is by looking in the inlet of the muffler.
The Xtremes have a "straight-pipe" parallel with the muffler like this, a friend of mine has them on his H/C/I c5 Z06, it sounds sooo crazy good! The Touring/Pace Cars look the same from the outside, not sure how to tell those two apart except that the Touring mufflers sound almost no different than stock. I'm excited to hear them with the Tri-Y's.
I'll have to tell you about rat poop soup you can get in Ghana...
Btw, I have the Casper square port extensions. I decided against reusing the O2 sensors stuck in my stock exhaust and went with the Bosch Vette Rear 02s for my car, so I'm just sitting on these Casper extensions.
I'm definitely a bit frustrated at this point. I'll cut into the starter with a grinder though before I dent that primary.
Guy on CorvetteForum had the same problem as me, also with 1 7/8" primaries. He opted to heat and dent it.
At least the X fits good and looks good.
Good on you going thru the motions!
