Stock ls2 heads and ls6 can for $300... Should I go for it?!
I can snag a set of ls2 heads and ls6 can with ls6 springs for $300.. I have an auto 02 SS with long tubes, lid, ory, 3.23's ls6 intake. How much power would this combo make? I know the cams small, but it's bigger than my stock cam!
Thanks!
Thanks!
LS1Tech Premium Sponsor
No way would stock LS2 heads and an LS6 cam make 50rwhp. I can see 50 fwhp though. You'd gain much more by just simply replacing the camshaft with a good aftermarket cam properly specced for your vehicle and needs. Remember that although the heads and cam is $300 you will also need all of the gaskets and hardware to install everything, not to mention the fluids to replace what was lost in the instal.
Thank you,
Lonnie
Thank you,
Lonnie
seriously if you can get that setup for 300 bucks that's great. you can sell the cam for $100 buck and put it towards a new cam which is around 350-450 depending on vendor. Do you have any ideas on what cam you would upgrade too or would you do a custom cam for your build??
