EFI Electric Fuel Pump
I'm making 600+hp on E85, at 42psi. So I need a minimum of 65 gal/hr (432#/hr).
I looked at both Weldon and Magnafuel. Both considerably more expensive than Aeromotive. Not that concerned about the price, as long as the part will last. I also looked at Quick Fuel, but they're for carbs.
Any thoughts/experience with either Magnafuel or Weldon?
Any other part I should be looking at?
At the moment, I'm leaning towards the Magnaflow, only because it would be easy to mount in my car, in place of the Aeromotive.
http://www.lonniesperformance.com/
I could use a stock type Mustang hanger, with pump, pick up, and return. But for this fuel cell, the only thing that fits is 87-93. And the feed and return lines are too small. Not a whole lot of choices for a Ford guy. So, I end up using an external pump.
One of the reasons my new track car will be Chevy powered. Lots of good choices there.
pump that ought to be readily available, and capable of
at least feeding a 6.0 at our 4-bar pressure. Maybe you
parallel two of 'em for more, if need be.
The pump seems to be under a heat shield just fore
of the filter and the big, long-*** tank on the driver's
side. Motor is the old iron 5.7 controlled by a "411" PCM.
under the heat shield is the EVAP crap and the whining is
inside the tank.
I do know our Lincoln MkVII has an external pump because
I changed that once. Whether it's any good for a big LSX
at 4 bar, when it's meant for a 5.0 at 3 bar, I dunno.
Maybe some of the fox body mustang / late-'80s Ford fans
do, or maybe have a line on uprated stuff.
Newer Mustang GT's have the pump mounted in the center, instead of on the right side. For those you can buy a special billit hat that mounts two pumps. Very expensive.
