FAST 102 vs. LS6?
Old Jul 1, 2014 | 07:36 AM
dsadsdaiouser's Avatar
Default FAST 102 vs. LS6?
How much more rwhp can you see from a FAST 102 (and supporting TB) over the stock LS6 intake? I'm trying to decide if the swap is worth it. We have a 2004 C5 with bolt-ons and an IHRA Pure Stock cam (factory lift AND duration) that makes 372 to the wheels. In good air it will run 11.50s. Currently we also have a wet kit and on a 100 jet (with the NANO also) it made 502. Once we sort it out and get the progressive controller adjusted our hope is to go 10.50s.
Our next step is to have Phil at AI do a set of 243 heads and add a Tick Stage III SNS cam in hopes of going solidly in the 9s. My question is while everything is apart how much can you expect to see from just the FAST 102 intake and TB? I ask because it's going to be about $1500 to do the intake, TB and new 102 nitrous plate. If we're only going to see minimal gains at the wheels I'll just leave the LS6 intake on. I don't mind spending the money but want to make sure it's worth it before we go that direction. Keep in mind that we only have 100 jets in now and can easily go 150 for free but I want to know if the stock intake at some point is going to become too restrictive.
Any real world experience with this?
Thanks.
Scott
Old Jul 1, 2014 | 07:40 AM
Mgg4591's Avatar
https://ls1tech.com/forums/generatio...take-swap.html
https://ls1tech.com/forums/generatio...e-vs-fast.html
Old Jul 1, 2014 | 08:26 AM
Thanks. Even on a H/C car it doesn't seem like 20 rwhp would be worth that much money.
Scott
Old Jul 1, 2014 | 09:25 AM
HCI2000SS's Avatar
Only you can determine if the bang is worth the buck
Old Jul 1, 2014 | 09:34 AM
Rise of the Phoenix's Avatar
The price is not worth the power gain in my opinion, but I'm not a wealthy man. If you are, then by all means go for it. Or, since you're already on the bottle, just up the shot.
Old Jul 1, 2014 | 09:38 AM
HCI2000SS's Avatar
I like Phoenix's idea actually lol. That's what I'd do...and have actually
Old Jul 1, 2014 | 10:02 AM
Larger jets are waaay cheaper than anything branded FAST.
Old Jul 1, 2014 | 01:59 PM
Thanks gentlemen. Those were my thoughts originally but I wanted to hear from others. I'll just stick with the LS6 intake when I do my H/C and jet up the plate if I need to go quicker. 9s were our goal and I think that is realistic with the OEM intake.
Scott
Old Jul 1, 2014 | 03:38 PM
Scott
Yeah, I agree. I think that's the smart thing to do. You can always upgrade the intake after doing the heads/cam swap.
Old Jul 1, 2014 | 03:59 PM
garygnu's Avatar
consider a bbk intake ,used $300 .it will make a little more power ,and safer with the nos .
Old Jul 3, 2014 | 10:20 PM
Always2Slow's Avatar
Fast 92mm is really worth doing if you can afford that. Properly ported you will gain throughout your powerband while racing.
Old Jul 4, 2014 | 05:27 PM
BrntWS6's Avatar
Its not much for the money you throw at it....but the gains are from ~4k rpms all the way to
Redline. They are a pain to tune right....mine still runs rough with the A/C on.
Old Jul 7, 2014 | 02:01 PM
Sales@Tick's Avatar
We prefer the Fast 92 intakes in this application.
Old Jul 8, 2014 | 06:37 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Scott
Hmmmm.... That could be the difference between a 440 car and a 460 car. I'd go Fast 92 and not even give it a second thought.
Old Jul 8, 2014 | 06:50 AM
redtan's Avatar
On a nitrous setup yes that may be true. But on a purely N/A car you're going to have a tough time getting more hp/$ ratio at that point.
$300 for 20rwhp at this point is as good as you'll get without going with more nitrous or boost.
Old Jul 8, 2014 | 07:51 AM
HioSSilver's Avatar
The fasts are worth it. To be honest if you can fit a lsx rt on your car you would be looking closer to 30hp. When I changed from a ls6 to a fast 90 I pick up 13hp at peak and near 18 at other places under the curve. I noticed better throttle response and it seemed to carry the power better.
Old Jul 11, 2014 | 12:40 PM
35thredz's Avatar
Port your ls6 intake and don't fall into the Fast nut swinger crowd! A tpis ls6 will do just as good if not better on a street car.... unless your turning 7000rpm between red lights!!
Old Jul 11, 2014 | 02:08 PM
dr_whigham's Avatar
The Scammer Hammer
Right. Because we're atomizing fuel and the size of the TB, not the design of the manifolds runners matter, right?
Your statement is 100% false and it's been said 300 times on here by anyone with decent knowledge that there's nothing to be had by porting an LS6 or changing the size of the TB.
You gain power EVERYWHERE with a Fast, not just peak.
Old Jul 11, 2014 | 02:13 PM
HioSSilver's Avatar
Actually there is some to be gained by porting a ls6. Maybe 5-6 hp from my experience. The problem is I gained 13-14 over the ported ls6 with the ported fast.
But then I am turning near 7000rpm. The lsx rt is the way to go if you can make it fit.
Old Jul 11, 2014 | 03:03 PM
dr_whigham's Avatar
The Scammer Hammer
Originally Posted by HioSSilver
Actually there is some to be gained by porting a ls6. Maybe 5-6 hp from my experience. The problem is I gained 13-14 over the ported ls6 with the ported fast. But then I am turning near 7000rpm. The lsx rt is the way to go if you can make it fit.
I agree with the RT. If I could fit it, it'd be in the car, and I'd be damn proud of it too!
Hio you're the exception to the rule. Your car does things others just don't
That's a compliment, btw
