Single Cat on I-Pipe Instead of Dual cats on Y-pipe
My goals: Replace stock manifolds and Y-pipe with the BBK longtube + Y-pipe package (Non catted Y). I want to install an electric cutout followed by a single magnaflow cat on the I-pipe so that i can switch between open header mode and cat+muffler mode.
My concern is, can i still pass emissions with a single cat on the i-pipe rather than dual cats on the Y. (I live in Texas). I would buy the biggest converter magnaflow sells, rated to handle a 7.8L.
Has anyone ever tried anything like this? Anyone think i can pass emissions with this setup and the cutout closed?
If you do want one that will still be somewhat effective then install a magnaflow # 59959 right off the bbk y-pipe and then into a E-cutout exit.. Now if you want a little better flow the you'll need to replace the bbk y-pipe merger with one that has a larger 3.5" outlet, then install a magnaflow #59920 which has 3.5" inlet/outlet, followed by a 3.5" E-cutout into a 3.5" to 3" reducer going back into the cat-back before the over-axle pipe. FYI the single cat won't reduce the overall loudness a lot, but it will give the exhaust a better sound.
Why would you even want to consider doing that ?
Adding a rear O2 sensor behind a converter that's to far back is only going to set a code, since it won't be able to get hot enough to be 100% effective at converting harmful compounds to harmless. So, spending the time and money to install a rear O2 is only going to tell you what you already know.
FYI, it's the same reason that the rear O2 sensor are removed(or disconnected) and either tuned out or replaced with O2 Sims when L.T. headers are installed; converter inefficiency.
I'm running:
Pace Setter Coated LT's
Pace Setter Y PS82-1163 and IZM993-2 O2 sensors, with dual DMH cutouts on the Y-pipe
Magnaflow 14419 muffler used inline with I pipe
Walker 54064 (I-pipe)
Walker 53061 (I-pipe)
CME Exhaust tips and elbows
Dynomax, Ultra Flo Welded, muffler #17227
I'm considering putting in a high flow cat 59959 before the 14419. Would this help with exhaust fumes when I have the cutouts closed, or is it not even worth the effort?
