New intake at SEMA: MSD Airforce
I just looked at the truck intake and its a monster lol. The plenum volume on that thing is just nuts so idk that this will compete with that. more so i think/ hope the hp will be on par with a car 102
But it makes power so I could learn to live with it I bet
https://ls1tech.com/forums/generatio...l#post15975179
It is hard to say without actually having one to test yet. It would be amazing if it does and if it really does im sure it will be a high demand part. As far as the rail situation it really does not change much from going to a 102 FAST set up as the 102 FAST uses the LS2 rails on the LS1 cars in the first place unless you go to a billet rail set up. The concerns of it fitting under the cowl are real enough but is hard to speculate until they are actually out and are on the cars to see first hand.
Thanks
Derek
Seriously though, I fully expected this intake to cost more than the fast. If it makes more power than the fast & we all know how well the fast sell. So it makes sense from a buisness standpoint to mark them a little higher. Just the way it is. I'll still buy one if it makes 10+ over a ported fast.
Wasup, hope some body else too is getting the idea.
These two intakes (LS and LT1) should be out late first quarter, 2015.
These were tested and dynode by Lingenfelter and were done on fairly stout engines. I asked them to publish WHAT it was dynode on so we can have a reference, and they said they would when it was released. There was a C7 out in the main entry way that had the LT1 intake on. They designed it to fit in the factory location.
They had the intake separated on a separate display and the runners are pretty straight shots into the head. Were a little beefy so they could be massaged a little for someone wanting to do their own port work.
LS is going to be around $950, LT1 will be around $1100.
