new intake on the block
thats great you got a good deal
The alignment of the ports look pretty poor, I'm wondering if they can be pushed into position.
Honestly, the dyno graph shows it's not that far behind the real LS6 manifold. If the tubes can be better aligned it might improve.
As expected, the F.A.S.T. is a better manifold.
Now we need someone to pressure test it to 40lbs and see if it pops!
I've got to say I'm a little disappointed with those dyno numbers I expected the Dorman intake to be slightly ahead of the LS6, but it was close. That motor showed a 30 hp gain with a FAST 92 over the LS6, thats a pretty big gain showing that this motor can handle all the air it can get so it is going to magnify any loses in hp also. The Dorman was 7 hp down from the LS6 at peak thats only a 1.5% loss and could likely be made up with porting.
way to go, dorman. not even on par with an LS6.
anyway, i really think the dorman-designed top shell is what's killing the whole manifold's performance.
if it were still possible to obtain a FAST 78/90 top shell, it might have been a worthwhile endeavor to cut the dorman top off, use the FAST top shell instead, and reseal everything with RTV. that would still be a ton of work, and in the end even if it was cheaper, you still could have purchased a FAST 92 new and saved yourself all the trouble.
also, the difference is closer to 10 hp according to that graph. that's significant in my opinion.
lastly, there is no data on a ported dorman yet. speculations on the performance of a ported unit are just that.
