LS6 pcv system
Old 02-08-2015, 09:15 PM
gmoutdoorsman's Avatar
Default LS6 pcv system
I'm switching my pcv system on my 347 iron block build to an LS6 style. I've already acquired the LS6 valley cover, my question is how do I go about plugging the existing pcv tubes in my valve covers, do I need to block both off? And do I use the GM# 12568011?
Old 02-08-2015, 09:30 PM
2001AntiVenom's Avatar
You need the hose in post 6 if you don't plan on using a catch can
https://ls1tech.com/forums/generatio...-pcv-help.html
Yea that cap will work for the rear passenger vacume port
You will use a rubber vacume cap for the driver side
Old 02-09-2015, 06:03 AM
Plug and hose ordered, thank you very much
Quick Reply: LS6 pcv system
