Dorman ls2 intake?
Old May 8, 2017 | 04:00 PM
  #241
LaBLKv6Z's Avatar
Originally Posted by omc8
The mad rush for the intake has seemed to have slowed down. Which is surprising to me I would have guested it to carry out a bit longer. Rockauto has cornered the online market on these for now . Id ltk ... How many guys have installed and are running the LS2D and Warr 92 tb combo now ?
I'm running the WARR 92mm TB, its a nice piece.
Old May 8, 2017 | 04:57 PM
  #242
tech@WS6store's Avatar
LS1Tech Premium Sponsor
We have sold a few with billet rails and a few diff 92mm tbs. mostly the holley sniper (with new iac) and the nick williams. We try to keep 5 on hand at all times. The sniper tb is on back order so we offer a few diff options. We sell whole kits ready to go with holley adj tb bracket for $689 shipped or pieced out also. We have it complete for the swap guys that dont have any orig parts. But we can sell without bracket for $660. And it goes down from there. We will also be offering ported options as well!
For more info email me as we dont have it completely listed yet.
Old May 8, 2017 | 06:02 PM
  #243
Do you also handle the Dorman LS6? If so, does it sell well? What are your thoughts on it? (Sorry for the one-post hijack!)
Old May 8, 2017 | 06:17 PM
  #244
ironmanLS1's Avatar
Originally Posted by LaBLKv6Z
Will report back when I get to hit the track.
Any track numbers yet?
Old May 8, 2017 | 06:37 PM
  #245
We do have them. They are not AS popular based of recent findings, but good for those price gougers online wanting 450 for a bare intake lol. As the ls swap world grows both of these intakes will keep growing in volume. It is a good intake just needs a little attention out of the box like the ls2 and truck intake does. Then they are great.
The emissions guys in cali etc should really like em due to keeping the egr and not modifying a huge amount.
Old May 8, 2017 | 07:38 PM
  #246
ironmanLS1's Avatar
Are you referring to the new revision released with the larger 90mm throttle body opening? I only see a couple reports which seem positive, every other search I find seems to talk about the first round with the smaller opening.
Old May 8, 2017 | 08:00 PM
  #247
Dorman has both intakes. Both the 3 bolt ls6 style and the 4 bolt ls2 style.
There have been a few "minor" revisions in each style but both are pretty good now imo.
I mean the ls6 isnt as popular recently as the ls2 because of recent flow charts floatin around and a few dyno results.
Old May 8, 2017 | 10:43 PM
  #248
I was thinking with the popularity of the 5.3, the LS6 Dorman would be great for those needing a lower profile manifold than the truck manifold. If it was decent for the LS6, it should have flow capacity to spare for a nicely warmed-over 5.3
Old May 9, 2017 | 08:21 AM
  #249
Kfxguy's Avatar
So has anyone done any back to back dyno testing of this intake? It would be worthwhile to see if it makes more power with a 92mm throttle body vs a ls6 with a stock throttle body.
Old May 9, 2017 | 10:40 AM
  #250
omc8's Avatar
Originally Posted by Zach-R
Thats the setup I'm running. I came from a ls1 intake and ported tb. It was a noticeable upgrade on the butt dyno. I made a thread about the install and how I did it.
https://ls1tech.com/forums/generatio...s2-intake.html
Thanks for the install thread , you were the first to mention the hvac port.
Thanks for dyno results on your combo.
So far its just Zach-R , LaBLKv6Z and 99 Black Bird T/A are the only guys to install and run , post review. I may have missed someone please post up lmk. There have been quite a few sold , but not posted a review that I know of.
Old May 10, 2017 | 12:10 AM
  #251
Don Nguyen's Avatar
Anyone used the ls2 dorman intake on a boosted set up? I remember seeing the ls6 dorman intakes blow apart, which kept me away from them previously.
Old May 10, 2017 | 12:18 AM
  #252
For everyone's curiosity we will be pressuring up one of these manifolds soon. Off the vehicle. Ports closed off with a pressure gauge on it. Im guessing 20lbs should suffice?
I think as a courtesy to the customers that buy our intake combo, we will be pressure testing each of them. That way its not a "luck of the draw" kind of issue. If there are any issues we will address them. That way we dont have to worry about shipping back and forth etc.
Ill have more info when we get everything together!
Old May 10, 2017 | 04:24 AM
  #253
99 Black Bird T/A's Avatar
I have a Dorman LS2 intake but is not installed on either of my cars. I'd planned to put it and fest but scored an ERL 416 and went down another path. The shop that built my 91 RS with the TPIS 90mm snout ported LS6 offered to swap on the Dorman LS2 and dyno test it. We also tested several other intakes on my 91RS. However, the RS runs very well and has perfectly stock driveability so I'm not willing to tinker with the set up now that the car is together and right after a ten month restoration.
Old May 10, 2017 | 10:28 AM
  #254
omc8's Avatar
Ok thanks for clarifying that , if you ever do install that combo please update us.
Old May 14, 2017 | 02:02 PM
  #255
Zach-R's Avatar
I explained what to do in my write up for the map sensor hole on this intake. The hole is the same size as the factory egr hole but slightly deeper. I had to use a rubber expansion plug to fill it. I show my car alot and would love to find a better looking alternative.
Old May 14, 2017 | 02:14 PM
  #256
Zach
http://www.ws6project.com/user_stor/catalog/product_info.php?cPath=235_82_380&products_id=4790
Also avail in polished.
(Copy and paste if clicking hyperlink doesnt work)
Old May 14, 2017 | 08:24 PM
  #257
Zach-R's Avatar
Zach
http://www.ws6project.com/user_stor/...oducts_id=4790
Im not sure that will work. I had a similar block off from ict billet and it worked perfect for the ls1 intake. However I found the ls2 intale to have a deeper hole. So it actually wouldnt seal and had a terrible vacuum leak. Id gladly buy your block off if i knew for a fact it worked.
Old May 14, 2017 | 08:29 PM
  #258
Give me dimensions, ill measure ours.
Old May 14, 2017 | 08:31 PM
  #259
The alternative is to use an actual freeze plug and drive it into the intake. Quite a few do this on ls1 and truck intakes. Then paint it or fill it with epoxy etc.
Old May 15, 2017 | 09:26 AM
  #260
omc8's Avatar
would you remove the white one from a LS6D 615-900 , shoot a pic and compare dimensions with your billet plug.
