H/c/i install question
Old Apr 14, 2015 | 07:47 PM
johnjr45's Avatar
Default H/c/i install question
I'm gonna install heads cam and intake fast 102 with 92mm throttle body next weekend will I be alright to drive it real easy 45 mints away from me to get it tuned??
Old Apr 14, 2015 | 08:31 PM
kinglt-1's Avatar
Get a base tune first if possible. If you are changing injectors which you will most likely need to, then you do not want to start the car until the proper injector data is programmed in the pcm. Aside from that it will be easier to drive on a base tune...ie less stalling and surging then no.tune at all. Maybe the dyno shop can send you a base?
Old Apr 15, 2015 | 07:46 AM
redtan's Avatar
If you change the injectors absolutely not.
If you don't change the injectors, you might be able to baby it to the tuner but it's gonna run and drive like crap. Either get a baseline tune or tow it, not worth the hassle to try and drive it.
Old Apr 15, 2015 | 07:55 AM
redbird555's Avatar
what size is the cam? Putting a few street miles on the car and letting it idle will get the pcm somewhat used to everything and make it drive better but if its real extreme it may not like it.
If you have injectors dont put them on till you get to the tuner.
Old Apr 15, 2015 | 08:45 AM
MonmouthCtyLS7's Avatar
Pay the 100 bucks for the tow.
Old Apr 15, 2015 | 08:53 AM
dsadsdaiouser's Avatar
What about the same situation but we have a trailer and need to start it just to load it? I'm assuming that running it for a minute or so to get it on the trailer will be fine.
Scott
Old Apr 15, 2015 | 10:13 AM
johnjr45's Avatar
its brian tooley stage 2 cam. I got a car trailer from a friend so gonna trailer it down. thanks for info guys.
Old Apr 15, 2015 | 10:26 AM
johnjr45's Avatar
anyone wanna take stab at what it will make for rwhp
2000 ta stock bottom end
ported 241's
brian tooley stage 2 cam lifters springs pushrods
fast 102mm
92mm tb
texas speed long tubes with catted ypipe
42lb injectors
slp lid
borla catback exhaust
slp timing chain and ported oil pump
Old Apr 15, 2015 | 11:13 AM
redtan's Avatar
Depending who ported the 241s and the final compression, I'd say anywhere from 410-440rwhp.
