Bolt on catalytic converters
http://www.summitracing.com/parts/mpe-23477
http://www.summitracing.com/parts/mpe-23489
If you have a jack and socket set you should be able to handle it, fairly straight forward..
Get the car up to operating temp, jack the front of the car up and while the engine is hot un bolt the cats to the exhaust manifolds..
I like to do it while it's hot since those bolts are usually rusted and can break when removing.. When they are hot they should break loose easily..
After you break the bolts loose a few turns, take a 30 min break and then come back when everything is cool..
