New Hooker 4th-gen F-body Headers and Exhaust
#541
So it is possible to start with the 50 state version and then change to off road?
I -just- got a 2002 WS6 with stock exhaust. I'd like to start with this as my exhaust option and then move to heads/cam/long-tubes with this exhaust in 2017 ... if that makes sense ...
#542
Now if you're referring to switching to their mid-length headers later on, I can't answer that. I don't think they have any plans to sell the different adapters separately, but Toddoky would have to confirm.
#543
Yes because it requires a little custom fab work to mate up with long tubes regardless of which version you get. When you're ready to go to long tubes you'll just need to purchase a couple 3"-2.5" reducers and maybe a few inches of 2.5" tube and have it welded or clamped up.
#544
Hey Toddoky -
Any word on the timing of the 50-state legal dyno run?
Ultimately, it'd be great to have the same vehicle with a baseline run, a run with the 50 state legal version, and a run with the headers and true dual setup. I know there'd be a little cost with that, but I think it could go a long way to dismissing that the midlengths are a bottleneck, or that the 2.5" piping isn't efficient. My point is, it could be a good investment to get people into your product.
#545
Hey Toddoky -
#547
I think i'm going to pull the trigger on this setup, but i will be modifying it to work with my longtubes. Anybody know which configuration is going to be the easiest to modify for this purpose? My thought was the off road version would be the easiest to modify based on the photos, but wanted to know if anybody had any experience.
Also, what is the primary difference between the $783 system, and the $1000 system? Is it 409 vs 304 ss?
Thanks
Thanks
#549
I'm more curious which system would be easier to modify, if i'm going to use it with my longtubes. It appears the 'off road' system has an extra clamp on the passenger side before the X pipe.
Thanks
#551
Thanks for the link. I ended up ordering the 'off-road' system, the same as him. I'll be adapting it to my longtubes over the next couple of weeks. I'll post a few sound clips of the difference between my TSP dumped duals, and this system, as well as some clearance shots.
#552
Here's a permalink to my experience with adapting it to my longtubes. If you ask me, Hooker took it into account that people would do this adaptation and designed the system so you could easily do so.
https://ls1tech.com/forums/generatio...l#post19219838
#553
I've jumped in and bought the Off Road version(70501413-RHKR) for my '00 SS. I also ordered SE 1 7/8 headers on Friday. Looks like the only other items I need to purchase are the following:
(2) Flomaster R3025 reducers
(2) 3" band clamps for clamping reducers to headers
(2) 2.5" band clamps for clamping reducers to TS's
Does this look like everything I need for a non-catted conversion to LT's?
Anyone have questions or would like photos of anything during my install?
#554
Just as an FYI, i had some issues with the supplied clamps leaking where the reducers came together with the system, and also on the passengers side before the X Pipe. I bought some dynomax band clamps and that seems to have solved it. I also noticed there is a small pinhole leak in the weld on the rear most side of the x-pipe. After a couple of months with the system installed, I'm still very pleased for the price point. It made me actually want to drive my car again, where as with the TSP dumped duals, I was tired of it after about 15 minutes.
#556
#557
My off road kit came in yesterday. I havent looked at everything yet, but nice looking parts parts so far. There are a few burrs here and there and the inside of the X Pipe looks pretty rugged. I plan to extend a carbide bit on a die grinder to smooth it out a bit. I'm pretty excited about installing this system.
Atrus, I'm in a similar situation as you. My pipes are here but my LT headers won't be until Monday. So I plan to be start on my exhaust first over the weekend. I hope the rest of your install goes smoothly.
#558
I'm actually heading out of town for a car show on Wed, so I don't know that I'll have time to get it installed and tuned before I go on a road trip. I'll most likely get the install done over the longer weekend of the 4th.
#559
I installed mine the other day. I shot a very short clip. I'll have to get a better one once I get tuned. I just bought my car 3 weeks ago and it had a Flowmaster catback with stock cats and manifolds to this system with the headers and no cats. I'd say it's only slightly louder at idle versus my flowmaster, very similar just cruising down the road, but get on it at all and it opens up much louder than the flowmaster did. It sounds absolutely incredible and I haven't even gone past 1/2 to 3/4 throttle yet.
This video is with my t-tops open.
https://drive.google.com/file/d/0B_p...ew?usp=sharing
Also thanks to Mike at WS6 Store! Great guy and super fast shipment.
#560
Car is 18" to the K member as recommended by folks on here. LT's won't be here until Monday, but I have began. All old exhaust has been removed(still have to remove manifolds).
Stock exhaust weight including everything in photo below is 67lbs (w/o manifolds). I plan to do a total weight of my old exhaust and compare it to my new which is 1 7/8 LT and the offroad BH.
As I mentioned in a previous post, I cleaned up the inside of the X-pipe a little. Below is a photo after a little bit of progress. I wish I had a before photo. I have no idea if this will help anything, but my machinist impulses took over and I have to smooth it out. I used a spade bit extension and a carbide burr follow by a sanding flapper.
