Jegs catback+Long tubes?
Will it fit to the ORY with no issues? Also, will the sound profile be significantly different than the rumbler? Also curious about tips, could someone recommend a set of "stock style" mailbox tips or other single (not slash cut) tip with 2.5" inlet?
Thanks guys!
It was ok, but I realized I don't like the sound of the chambered muffler and it really accentuated the rasp from 1800-2200 rpm. It's higher pitched than I was expecting, the only way I can describe it as "euro-ish".
I switched to a Magnaflow muffler, and it's much more my style and like half the size.
As far as fitment, the I-pipe fit my Pacesetter y with no problems, but the drivers side exhaust hanger is a joke.
It's a bent rod, threaded at one end, that you thread into a bolt that is welded to the exhaust pipe. The bolt on mine was welded on so caddywompus that I had to grind it off and make my own, cause nothing even came close to lining up.
For $270 or whatever it is now, it gets the job done with some tweaking. As best as I can tell, both the Jegs and the Summit cat-backs are the same and both made by Heart-Throb.
Im thinking of buying the jegs catback, and buying a set of those, cutting some of the excess pipe you see inside the tip on the ebay page, then putting those on the jegs catback as tips(cutting pipe as necessary). I figured it would have that "slp powerflo" look to it, and from what I can tell are basically bullet muffler/resonators. I don't feel it would look too "ricey", but would like some opinions on how to proceed. Not a fan of corsa clone tips and would like a bit of extra noise control.
