DMH cutout burned up?
Old Jun 14, 2015 | 03:00 PM
allbaugh_04's Avatar
Default DMH cutout burned up?
So I've had a DMH cutout for probably 5 years now. It only opens today, won't close.
Safe to assume to motor is done for? Do I purchase a new one from DMH or try a new setup or motor? They do make the best cutout motor correct?
Can they even be rebuilt? I emailed them months ago...no response.
Old Jun 14, 2015 | 03:04 PM
98CayenneT/A's Avatar
If you get another one check this one out, I have it and love it
http://raceland.com/electric-cut-out...st-system.html
Old Jun 14, 2015 | 03:32 PM
ULTIMATEORANGESS's Avatar
Smile
id figure which is cheaper and easier to repair or replace it.
Old Jun 14, 2015 | 03:43 PM
That looks nice, but I'd have to re-weld the exhaust piece in.
Probably buying another DMH without the wiring is the best idea then. $179
I guess I was mostly curious if the motors could be rebuilt easily.
Old Jun 15, 2015 | 12:32 PM
jimmyblue's Avatar
Moderator
It seems unlikely (though not impossible) that the
motor would fail in one direction but not the other.
I think I'd be looking to the switch and close-in
wiring, with a meter on the motor terminals so you
can see whether it's electrically lit and not moving,
or not lit in the "close" direction.
Also check for some mechanical bind at the limit of
open-travel, which might exceed motor stall torque.
If you "help" it a little, does it commence to work?
Quite likely the motor itself is cheap and available
(but where, that's the question). Maybe you can find
a P/N or mfr and scare up its replacement on eBay,
surpluscenter dot com or places like that. I'm pretty
sure it's a generic 12V motor with tapped holes on
the face, and a particular gear (pressing on and off,
may be the trickiest part of a transplant).
Might also disassemble the gearbox and give it some
grease; this is where cutout failures start, with
overloading the motor and overstressing the gears
against too much friction.
Old Jun 15, 2015 | 12:52 PM
slow trap's Avatar
look on it for the serial number. it will be 3919,3919a or 3782.
call multi products @ 877-444-1011. lori ext. 221
Old Jun 15, 2015 | 08:03 PM
I also was surprised it failed in one direction.
I wanted to "help it", but not possible to do alone.
I'll look again for P/N and such, I didn't see anything jump out, but maybe if I take it apart I could find something.
You're sure they have that motor then? I will get it taken off again and try to look for the number.
Thanks guys!
Old Jun 15, 2015 | 08:37 PM
jblankenship's Avatar
On mine the solder broke off the wires going to the motor, but then it would not work at all. I would also suspect the switch. The switch is a double pole double throw. So with a volt tester on it should show +12 in one direction and -12 in the other.
