Going for it.
Old Sep 16, 2015 | 03:13 PM
john stewart's Avatar
Default Going for it.
looking for advise on my si 2000 z28
241 heads 50k on motor
Ls6 intake slp lid
1 7/8 tsp headers ory and hooker cat back
strange single adj front shocks , moroso 275# trick springs. solid motor mounts
umi adj lca. adj relocated tq arm, lca relocation brackets .adj pan hard. ce 50.50 rear shocks stock rear springs
circle d 5c converter, b&m trans cooler,9inch 4.10s strange axels,spool,and wllwood dyna lite drag brakes.
big and little centerlines mickey et radials 275-60-15 and pro bracket 28x9
hp tuners pro
3450 race weight and the track goes at least -1000da in the fall.
Thankyou in advance for any advice, i am trying to get into the 11s.
P.S. this converter hits really hard lol.
Old Sep 16, 2015 | 07:03 PM
ULTIMATEORANGESS's Avatar
Smile
if your question is will you run 11s id say yes quite easily.
Old Sep 16, 2015 | 07:24 PM
I guess i was looking for input on what else i could do to get the most out of it , like water pump , pully, fast intake ect.
and what do you guys thick it will run thanks
Old Sep 16, 2015 | 07:37 PM
Smile
yes,those will help. a cutout will add more power also.
maybe look into a dyno tune.
Old Sep 17, 2015 | 05:22 AM
MonmouthCtyLS7's Avatar
What size stall? A Fast setup, Ud Pulleys and a bigger tb would help. You also might need injectors, I max'd my stock Vette ones out w/ the mods listed.
Old Sep 17, 2015 | 07:29 AM
its a circle d 5c witch is about 4400
and yes my injector duty cycle is at 94percent now there the stock 26ers
Old Sep 17, 2015 | 07:42 AM
11's should be cake w/ that stall if your able to get the power down.
Old Sep 23, 2015 | 08:18 PM
DarrenWS6's Avatar
Definitely time for a cage. Nice build.
Old Sep 24, 2015 | 03:41 AM
thankyou and yes roll bar will be coming soon as i just picked up a set of ls6 heads that i am going to port and install a cam around 230/232 111 600
this weekend is the ontario street car nationals so there will be lots of glue and rubber on the track for me to tt next weekend
Old Sep 24, 2015 | 06:39 AM
HCI2000SS's Avatar
Now that you have heads and a cam i'd shoot for 10's
