H-pipe or X-pipe with ASA cam?
ASA specs are 228/236 .525/.525 110 LSA
TSP 1-7/8 Headers as well
Is there any specific reason you are going with the ASA cam if you say you're looking for the most power?
Priorities. Fast first, cool sound second.
Before it, negates the advantages of the scavenging pipe altogether, but provides quicker access to open environment for the exhaust.
After it, you get the full effects of the scavenging pipe, but a longer distance for the exhaust to travel before reaching open environment.
Which is correct?
Which is correct?
I would think it would depend on application. If you have duals that are larger than needed I'm sure after the merge would be just as good if not better. But if you're pushing 500 HP through 2.5 in duals I'd think better gains would be had pre merge.
This is just my theory and I'm sure I'm probably in some way wrong.
I feel that the original question was answered rather thoroughly, unless I'm missing something.
From a performance and efficiency standpoint, the X-pipe is the clear winner.
For old school muscle car noises, the H-pipe is the correct choice.
You should probably get the X-pipe for the power gains across the board, and new rear gears to aid in down low grunt.
