Aftermarket valve covers
Attachment 522429
Attachment 522428
Attachment 522427
I really wish there were other valve cover options out there....
https://www.proformparts.com/common/...lve_Covers.pdf
Very disappointed in the coil relocation mounts and mounting hardware. Had to cut the coil relocation bracket and remove a 1.5" section to allow for stock fuel line connections to clear.
The mounting hardware is garbage and should be discarded properly. I went and purchased a nice set of SS Hex head 6mm bolts to mount the coil brackets to the relocation mount.
Also used a set of Teflon lined lock nuts on the brackets to the mounts. It feels much firmer now and in place.
The relocation mount tapped holes in the top section of the valve covers were not cleaned out properly. I ran a bottom tap in each hole several times to clean them out.
For $335.00 the quality is SUB-PAR. and you will need a 13" plug wire MSD part number 39849 at $115.00
I ordered a set of 11" Taylors that were too short, so don't make that mistake.
Here are a couple of pictures almost completed. It has taken me a little longer than expected due to the addition of the braided coolant crossover kit which I'm less that pleased with as well......lol
Photos attached
Photos attached
There are a couple different style kits but our most popular one comes with everything you need. It comes with the relocation brackets, different coil harnesses made for the relocation bracket, and a set of MSD universal wires. Price is $330 for the entire kit.
