K&N oil filter failure...beware
http://www.ls1gto.com/forums/showthread.php?t=28220
Not worth the risk when there's plenty of oil filters available without nuts at the bottom of them that are prone to leaking!
Here's yet another thread from some subuaru guy about this known issue with their shoddy spot welds inside the filters causing huge leaks from the 1" nut .
http://www.iwsti.com/forums/2-5-lite...il-filter.html
This was at a GM dealership so they just laugh and point the finger at aftermarket junk part failures.
On the positive side, my RMS is leak free and I got my filthy, probably decade old brake fluid bled while at the shop!
No idea other than it was 20 degrees first thing in the AM and I warmed it up for 5 mins before a 5 min drive....it was on tight as could be by hand confirmed by myself and the mechanic. It was not leaking out the gasket as the shop confirmed. I'm guessing the rapid temp change had something to do with it because it was completely leak free for several hundred miles before it completely failed on the coldest AM in a while.
I use either; Amsoil EaOs, Mobil 1 M1s, Fram Ultras, or Wix Golds (or NAPA, same thing), and have NEVER EVER had a failure, but I can say the same thing for the OLD, made in the good ol' USA K&N Golds when I used to use them.
