K&N oil filter failure...beware
Look up all the recent negative reviews on amazon about their wrench off filters!
You will see quality hit the skids recently and lots of other people have issues with the leaking nuts and gasket issues. Some have caused engine failures due to this. I'm not going to risk my engine or starting an oil fire using their POS. Feel free to do so if you wish!Regardless, other filers don't have leaky nut (
The singles I've bought previously were made in Mexico.
Do you have a actual explanation why you think that about Purolator because I don't think they are poor at all. Honestly that's all iv been using for the past couple years. This guy thinks they are good... http://minimopar.net/oilfilters/refe...html#l30001-99
In discussions of high performance use or "high end" filters, Purolator is usually not mentioned.
I will say this: Filters that have a rope/string around the filter media (such as most Purolator) have been known to slice through the media and allow unfiltered oil to sneak through. Filter media can expand and contract during use and the string stays one diameter. Some Motorcraft and Bosch filters are similar using this rope, no doubt made by Purolator.
The discussion in the link you provided even mentioned one new filter had damage from the string. Over time and use, this damage becomes a breach in the filter media.
If you've had good luck and are happy using Purolator filters, by all means continue to use it.
Yes I did read that too about the string. I usually get the Bosch its at the same place I get the oil. Never any problems but if I can do better I might as well order wix.
I also read that the k@n and mobile 1 are the same filter made by Champion Labs. Those two filters are the best Champ puts out they are of the Performance design. Looking at the other Champion labs filters I guess you could say most filters they put out are not very good either. If I was someone who usually picked up a k@n or mobile 1 filter I would have to confirm it was of the 1999-2008 Performance design and not the 2008 Ecore design. You never know when companies change things up.
Some guy mentioned how it wasn't a bad idea...
I don't think it filters more or has more flow as it moves through it's life cycle.
Like somebody else said, a decent filter isn't expensive. Why in the world would you NOT change the filter with the oil or not attempt to get the best filter you can for just a few bucks more?
Luckily the engine was fine but had to be towed home with very little oil left. Learned my lesson to check it every change now!
If you install filter without oil on the seal it is very hard to remove.
I can not tell you how many "seasoned" mechanics still practice installing
filter dry
I also have a slight leak around the K&N filter on my Z28 at the moment. It's not spewing, but definitely leaking somewhere. I ordered a new oil cooler bypass gasket for the fitting above the filter thinking that might be the culprit, so I'll know more once I put it up and change it...
I've been using the K&N HP-1007 on my Z28 for years, but if my current leaks turns out to be the filter, I'll be done with them too...
See that's what I'm talking about. Thinking we know who makes what filter according to independent tests and such then later down the road the company changes filter styles. Such a PITA to have to check and confirm what filter we are buying everytime. The pains us car guys go through?
Cant blaim ya there I wouldn't wanna use it either. Thanks for the info. Through your research were you able to find that k@n info you can post here?
http://www.gmforum.com/lounge-99/k-n...issues-308331/
"The K&N oil filters WERE made by Champion. Some industry info to pass along. UCI, who owns Champion Labs and Honeywell consumer products(Fram) were bought by a private company called The Rank group. This company merged the filter operations of Fram and Champion together and there were plant closings on the Fram end.
Since the merger/ buyout of Champion and Fram, K&N has contracted out the supply of their oil filters from Champion. The first vendor was in Mexico, then they moved to a Korean manufacturer, and now a Chinese manufacturer.
Reports are the internal quality of K&N oil filters are of very poor quality."
http://www.nastyz28.com/forum/showthread.php?t=267533
And
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=3101379&page=2
All this Tom-foolery going on with who makes what oil filter in the cheapest country on the cheapest low bid manufacturing line causes me to reassert that Wix filters are probably the best to use. Known quality and parts and build consistency.
For what it's worth, Amsoil is made by Wix and I believe Hastings and Baldwin are US made.
I used to use Fleetguard filters until I received offshore made versions that didn't have the correct innards.
My advice for filters: Choose a Wix XP filter for your vehicles and buy them in pairs (or more) on the internet, I've found rockauto and Amazon to have good pricing. I've yet to find a store that has Wix XP filters on the shelf.
And I can't believe anyone who changes oil doesn't attempt to fill the filter first and lube the seal. Imagine their attempts at pro-creating!
