Basic Bolton questions for 99 Z28
I have a 99 model so that also means I have the LS1 intake manifold with EGR still intact. I wanted to tackle this as well.
I want a LID and Im not too particular about what kind of LID. On Texas Speed I saw they have 104MM LID's for roughly $20 more than a standard LID, Its tempting but I'd also have to upgrade the MAF and Throttle Body for all this to work wouldn't I? Ontop of the Throttle Body I would need an intake manifold that would support that inlet..so my question is, for my power goal would it be worth it? For the Intake Manifold I was considering splurging for a F.A.S.T intake but leaving that one up in the air.
For exhaust, I am having a difficult time deciding as well.. Should I go for 1 - 7/8 or should 1 - 3/4" be enough? well, I should say I know 1 - 3/4" IS enough but I dont know if I should purchase that extra capacity "just incase"
Oppinions?
I put down 360/360 in a 00' Firehawk w/ M6.
1 3/4 LT's, 3in ORYP flowmaster merge, 25% U/D pulley, Fast Toys SSRA, SLP lid, stock T/B and LS1 intake.
You're gonna need a at least a cam to hit 400rwhp and supporting bolt ons. Just my .02
Heat kills transmissions
A good converter is hands down the best mod for A4 cars. It will also net you the best gain in drag racing. I have seen some take up to a full second off there times
Edit:
Here's what I intend on purchasing...
Intake:
FTP 104mm LID
http://www.ebay.com/itm/111845459830?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AITEGR Block Off
Exhaust:
Hooker Ceramic 1-3/4" LT's (chose 1 3/4" because the 1 7/8" version costs literally $400 more)
TSP True Duals
Stall:
What kind of stall should I go for?
Suspension:
Trying to avoid lowering the car at all costs. If I do, I dont want to drop more than 1" max. Otherwise going to look for 1LE suspension and a strut tower.
I may go for an LS6 intake manifold but after reevaluating its not the biggest of my priorities yet, I intend to upgrade it yes but not quite just yet as I may just skip directly to a FAST...
More so I'm racing the clock to get this stuff done before the EPA bans selling this gear. Doesn't have to be the fastest thing in the world, just needs to be fun. I do intend on getting a stall aswell but I'm unsure what RPM range I should aim for given I'm not cammed.
btw I selected the 104mm LID because the Throttle Body was already ported 102mm's. Decided it couldnt hurt.
FTI stall 3600-3800 range lock up. Yank and Circle D are good too
Browse for sale section for suspension stuff. I'm running spohn stuff but BMR UMI are good as well. Probably 5 others I'm forgetting.
Lowering is for looks. Thats not a must.
lowering control arms,Pan hard bar,torque arm,sub frame connectors
Next up are the headers, then the rest of the exhaust system. After that I'm going for suspension.
Also. I am running a heavy duty trans cooler but its from Autozone. Its mounted 1" infront of my condensor. Should I be okay with adding a stall? If so what kind of stall can I safely street drive the car with on a stock cam?
Can I swap over the arms between the two throttle bodies? (The arm on the 00-02 model is larger requiring a longer throttle cable) If so how?
It seems like your ideas are kind of all over the place. Your link for TSP true duals is actually Hooker true duals. And you're pairing it with Hooker ceramic coated 1-3/4" headers. For less money, why don't you go with a full TSP system and end up with stainless 1-7/8" headers (or 1-3/4" if you want)?
I would highly suggest calling a vendor before you keep ordering parts on ebay. They can help you decide and maybe steer you away from buying the wrong part(s). Texas Speed is just one example, and I've had nothing but success with them. Look at threads from others who have great things to say about help provided from other vendors, too.
Do you think the MAF just went bad? It does have over 200k miles on it and was recently tampered, or do you think its the MAF ends / no screen?
For everything else, I meant the Hooker exhaust, not TSP as I want an over the axle finish. I should ask though, will that clear the stock rearend with stock suspension? Also I am going to likely go for Speed Engineering 1 7/8" headers, heard good things about them.
