Dual exhaust
Old 03-12-2016, 05:36 PM
brewcrew011's Avatar
Default Dual exhaust
I just had dual exhaust installed on my Camaro. Speed engineering headers, x pipe, and 2 flowmaster 10 series mufflers. Love the sound at idle and when I get on it, my concerns are the slight drone at cruising and how damn loud it is. Anything i can add to it to quiet it down and get rid of some of the drone? Or is there no way and I need to replace the mufflers?
Old 03-12-2016, 06:58 PM
jig
jig's Avatar
A lot of people add resonators to their exhaust to help with that or cats
Old 03-12-2016, 07:10 PM
Any certain brand or type of resonator? And would that quiet it down at all or just get rid of some of the drone?
Old 03-12-2016, 08:48 PM
omc8's Avatar
True duals hih .....tell us what you got in detail . TSP dumped , ota all the way out back ?
Old 03-12-2016, 08:55 PM
They are custom out the back and over the axle
Old 03-12-2016, 09:03 PM
omc8's Avatar
Can't tell much from those pic's Do have good pics of your y annd x pipe
Old 03-12-2016, 09:07 PM
No y, just the x in the picture
Old 03-12-2016, 09:10 PM
omc8's Avatar
Can't tell anything from those pics
Old 03-12-2016, 09:30 PM
omc8's Avatar
Post up some better pics if you want help with this
Old 03-13-2016, 08:12 AM
1st pic is headers and flowmasters, second pic is farther down from the first pic with the x pipe then over the axle, third pic is after the axle to the tips. So it goes headers, flowmasters, then x pipe, then out
Old 03-13-2016, 08:34 AM
Toddoky's Avatar
The mufflers would be far more effective at attenuating drone if they were at the back of the car and were absorption style mufflers. Their current location also has a negative effect on your ground clearance, which you are going to realize at some point while driving the car.
Old 03-13-2016, 08:38 AM
Jay-P's Avatar
Muffler placement is not ideal imo. I would put resonators in place of the mufflers to gain some space up front, and try to put those mufflers after the axle... This might quiet it down and kill some drone.
[edit] Todd beat me to it. [/edit]
Old 03-13-2016, 09:20 AM
The 10's didnt fit after the axle, seemed like the only place to put them were up there. Ground clearence actually is very good, headers are the lowest part of all of it. What brand of resonator would be good for this? And would it quiet it down or just clean up the drone?
Old 03-13-2016, 07:48 PM
omc8's Avatar
Don't use the 10s get rid of them , bad placement . Second it appears the intermediate pipes coming off your mufflers are double 90* this does not help either . I would recommend redoing those also. I have to commend you for going the custom route, but you need a plan . Come up with a design for the complete exhaust system. If you go to the TDs exhaust sticky here there are probably a hundred pics of TDs . or just take a look at Kooks TDs is great designed system, not that should try and copy it but if yours is radically different , rethink what your doing.
Old 03-13-2016, 08:08 PM
Pretty much the same as kooks, same placement besides the 10s close to the headers, because with ground clearance they dont fit anywhere else. Bullets would fit anywhere, but i heard those were bad with drone and loud also. Wondering if i could add bullets farther down somewhere if that would help or if if i have to cut the 10s out and put a bigger muffler there. I dont think swapping the 10s for bullets are going to fix anything
Old 03-13-2016, 08:22 PM
omc8's Avatar
No you don't understand want I'm saying , it's not pretty much the same ! If want help with this pm me and I'll explain.
Old 03-13-2016, 08:35 PM
If it goes over the axle it has to bend like that. Same pipe routing as kooks besides the mufflers are too close to the headers is what im hearing. And placing bullets/resonators anywhere after the mufflers wont help. So ill try to find a quieter muffler that hopefully flows decent and try that i think
Old 03-13-2016, 08:49 PM
omc8's Avatar
No it's not , I offer to try and help. if decide too. I'll explain it pm me . If not good luck .
Old 03-14-2016, 03:41 PM
KingJacobo's Avatar
I run Moroso spiral flows and cats and have zero drone.
I'd look at picking up a pair of spiral flow bullets and see if they help.
Old 04-09-2016, 08:58 AM
I had two vibrant performance resonators installed right after the x pipe, before the axle, and it quieted it down nicely. Outside of the car at idle, drive by, ect it sounds perfect. Mean and deep but not too loud. Inside the car it still is quite loud, wish there was a way to fix that. If it was a dd car i would go insane haha
Quick Reply: Dual exhaust
