Solid Plate Motor Mounts
Are you trying to mount a LS motor in something using existing holes in the front and back of the block? I'm thinking a E30 is a BMW?
1. Avoid using the weak subframe
2. Avoid having to find a special header setup to fit around the mounts and steering linkage
3. Allow me to use the current steering setup, hopefully.
4. Mount will act as a brace and help stiffen the car.
I use Inventor Pro for all my drawings/modeling and I can do stress strain analysis if needed. The plate uses existing holes in the block and getting the dimensions correct is critical if you want it to fit without a ton of work. I picked the parts up Friday and they fit like a glove. I need to do a wee bit of grinding to clear gaskets and the driver side head. I'll try to snap some pictures soon of the finished plate on the engine but I do have one picture I took real quick.
Oil pan to cross member and steering rack clearance was on the money.
I'll reinstall everything in the car and tack weld the mounts in place on the plate. Remove the plate and finish weld it followed by sand blasting and paint.
I also took the opportunity to pick up some 1.5" DOM for the next part of the project.
make sure to die grind the water jetted edges. the garnet cutting media gets embedded in the cut edge and will contaminate your weld making it porous and prone to cracking.
