Radiator help please
Old Jun 11, 2016 | 11:14 AM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
Default Radiator help please
Got a picture here is this pose to be how the rad should be when stone cold?
I'm wondering if it's not ducking from the overflow when it gets cold and it's putting air into the system.
Make any sense?
Old Jun 11, 2016 | 11:17 AM
Cool28's Avatar
Also the overflow is at the same level that it was at when hot.
Old Jun 12, 2016 | 03:29 AM
NineZeroFive's Avatar
Looks fine to me. Are you overheating or something?
Old Jun 13, 2016 | 12:45 PM
psychosid30's Avatar
It's fine. Any higher and it will drain into the overflow anyways. When it's cold your radiator coolant level should be right below the overflow nipple and when you pull your overflow cap the coolant should be sitting on the cold marking on the level indicator hanging from the cap.
Old Jun 13, 2016 | 12:48 PM
I have a question though... What is the hose to the right of your radiator cap? It appears to be resting on a sharp looking piece of metal/plastic on the engine side of your radiator.
Old Jun 16, 2016 | 11:26 PM
Majestic9C1's Avatar
A/C high pressure line
Old Jun 17, 2016 | 07:35 AM
I'm not talking about the metal line to the left going to the condenser. I'm talking about the large rubber line to the right that looks like a big a** radiator hose. Maybe I'm just having an extended brain fart, but, it's got me stumped! LOL!
Old Jun 17, 2016 | 09:55 AM
oh ****.. lol I didnt notice that.... herp derp
Old Jun 17, 2016 | 11:58 AM
Cool28's Avatar
That's the blower hose.
Old Jun 17, 2016 | 12:23 PM
Well, that would explain it. Thanks, I was definitely brain farting over that one...
Old Jun 18, 2016 | 07:10 AM
Cool28's Avatar
Ya I think I had air in it cause I had people replace top and bottom hoses for the rad and I'm pretty sure they didn't purge the air after. I had huge air bubbles in the system.
Least I hope that's what it was...
Old Jun 18, 2016 | 07:24 AM
These cars can sometimes be a pain to bleed out. I try and put mine on an incline when I bleed it to force as much air as possible out on the initial fill up.
Old Jun 18, 2016 | 11:24 AM
Cool28's Avatar
Well after to new hoses andtrying to get the air out its the first time I seen the level drop when the thermostat opens since this engine was installed. I need to drive it around some and see XD.
Old Jun 18, 2016 | 11:32 AM
Nice. Good Luck!
