Harmonic Balancer Install
Old Jun 30, 2016 | 02:53 AM
69camarolsx's Avatar
Default Harmonic Balancer Install
Just installed my harmonic balancer using the proper tool, and it seems like the balancer stopped sooner than expected. I don't have any other accessories on the motor to verify pulley alignment. Does anyone have specs or pics of how much space should be between the seal & balancer? Here are a couple pics of what I got.
Old Jun 30, 2016 | 02:55 AM
Here is a pic between the balancer and crank seal.
Old Jun 30, 2016 | 04:03 AM
juniorssrollin's Avatar
Looks like your good to go.
Old Jun 30, 2016 | 01:15 PM
Cool, thanks for checking it out. It's been few years since I did my last one.
Old Jun 30, 2016 | 01:19 PM
psychosid30's Avatar
I just installed mine a few weeks ago and I have the same spacing you are showing. After fitting the accessories, the pulleys all line up properly.
Old Feb 1, 2018 | 09:10 PM
robbyt110's Avatar
does it matter where the balancer is positioned like it would on a crank with a key way? reason being i didnt mark the position when i took it off
Old Feb 1, 2018 | 09:14 PM
I don't think so. There are no timing marks on it to dictate that it should be in any particular position.
Old Feb 2, 2018 | 07:21 AM
01ssreda4's Avatar
No, it does not matter. Some aftermarket pulleys have timing marks that you could line up if you wanted to, but 99.9% of people dont worry about it.
Old Feb 2, 2018 | 07:54 AM
robbyt110's Avatar
awesome thanks
