Victor Jr. vs FAST 92mm
Old Aug 9, 2016 | 07:46 AM
Rise of the Phoenix's Avatar
Default Victor Jr. vs FAST 92mm
Trying to decide, based on my combo, which intake is going to yield better results. A Victor Jr. w/ 4150 style TB or a FAST 92/92 setup. I recently added bigger 1 7/8" headers to the combo, and while I picked up quite a bit of under the curve power and torque, it actually peaked lower than it did with the smaller 1 3/4" headers and really nosed over at around 6,000 RPM's. Martin Smallwood and Brian Tooley feel it's due to over-scavenging. I attached the graph below. Both feel that a better intake/TB setup will fix the issue. Based on my current setup, and the cam specs, which intake/TB setup do you think will be better, particularly in the upper RPM band (6,000 RPM+).
Current Mods:
AI Dart/RHS CNC ported 223cc heads
Tick Performance 227/235 110 LSA cam (Valve timing INT: 6 BTDC. 40 ABDC. Valve timing EXH: 50 BBDC. 4 ATDC. 107 Intake Center Line)
Speed Engineering 1 7/8" long tube headers
Texas Speed 3" true duals
Stock LS6 intake/stock TB
Accel 44lb/hr injectors
Old Aug 9, 2016 | 07:57 AM
HCI2000SS's Avatar
Unless im missing something, it says you're only making about 360 rwhp??
Old Aug 9, 2016 | 08:07 AM
Zmg00camaross's Avatar
^^ there is a thread about it. New dyno etc. I say fast 92. If you wanted to dip in the single plane world super Vic is the way to go on cathedral heads.
Also won't have to rev it as hard with the fast to get the potential out of it.
Old Aug 9, 2016 | 08:08 AM
KCS's Avatar
KCS
Moderator
The runners on the Vic Jr are shorter so they'll tend to perform better at higher RPM like what you're wanting. I think the 92mm has 10.5 or 11 inch long runners while the Vic Jr runners are 6.5 and 7.5 inch long. The Vic Jr tends to perform better with tighter LSA camshafts, so it may work really well with what you have now.
Old Aug 9, 2016 | 08:12 AM
HCI2000SS's Avatar
Ok I didn't know about the other thread. Don't you guys think with the current setup that the Fast would be a better overall performer?
Old Aug 9, 2016 | 08:14 AM
Here is the graph after he got the dyno setup/calibrated correctly.
Old Aug 9, 2016 | 08:18 AM
That's kind of what I was thinking too. I know guys like you are far smarter when it comes to cams and valve events, and I've always been told that if you're going to run a Victor Jr. or a Super Victor, you need to make sure the cam is spec'd for that particular intake. I was just curious with the valve events of my cam, if the Victor Jr. would be a better fit.
Old Aug 9, 2016 | 08:19 AM
HCI2000SS's Avatar
Ok that looks more like it. I was thinking for a moment that you had the lowest dynoed heads/cam LS1 ever lol
Old Aug 9, 2016 | 08:36 AM
It's my friend's dyno (Mustang Dyno) and it was basically brand new when we put the car on it. It took a little time for him to figure out the calibrations and get it working right.
Another questions is this: If I do a Victor Jr. setup, how much of a difference will there be between a 4150 TB versus an elbow/TB setup?
Old Aug 9, 2016 | 08:50 AM
KCS's Avatar
KCS
Moderator
I think the cam is going to make or break the manifold choice. Hot Rod did an article where they tested 20 manifolds and the Vic jr with a carb was actually down everywhere compared to a FAST 78mm. The cam was kind of weird though, it had a big split between the intake and exhaust like something for an LS3 application.
http://www.hotrod.com/articles/20-ls...ifolds-tested/
Meanwhile, there are several threads on here where people have picked up peak power over a FAST or LS6 intake, so results are kind of all over the place. I still think your cam is wrong for what you have, but it might be just right with a carb style intake.
Old Aug 9, 2016 | 09:05 AM
DietCoke's Avatar
throw the victor jr in the garbage and start with a super vic, or dont bother. Also, if you arent pulling it to 7600+ with the vic, you're going to go slower.
Old Aug 9, 2016 | 09:15 AM
I understand the single plane style intakes require more RPM, as that's where they shine, but are you saying you think I'd lose power in the lower RPM band with a Victor Jr.?
Only reason I'm contemplating a Victor Jr. is because I think it might be the best choice give my cam, and I don't want to have to cut up the car and lose wipers.
Old Aug 9, 2016 | 09:37 AM
thunderstruck507's Avatar
I don't think I've ever seen a combo where any intake performed better than a Fast as a whole for what I would want in a street car.
A hi ram type intake will make a good bit more starting above 5,000-5,500rpm or so and pull like mad well after a Fast noses over, but at the sacrifice of as much as ~25-30 hp below 5,000rpm.
And IIRC the mid length and short length carb style intakes usually perform worse everywhere. I might be mistaken on that though.
Old Aug 9, 2016 | 09:44 AM
kinglt-1's Avatar
Ported Fast.....
Old Aug 9, 2016 | 09:57 AM
You've got me seriously thinking about a LLSR cam. I know the cam I have right now is not ideal for the heads I have, so if I'm going to change it out at some point, maybe it wouldn't be a bad idea to go with a custom LLSR, especially if you can use stock rockers if you shim them.
Old Aug 9, 2016 | 10:11 AM
I have no complaints. Next time I have the covers off I need to pull some rockers and make sure I'm not getting abnormal wear on the valve stem tips or anything.
I wish I could accurately describe how different it feels to drive than before. The way power comes on is both more intense but smoother at the same time. It's not uncommon for LS engines to have massive power spikes above 4,000rpm but this is even more different than that.
The absolute best though is when I'm tearing up mountain roads and letting it hum along a sweeper at 4,000-4,500rpm then on corner exit rolling quick to WOT and the car just explodes out of the corner. It feels insanely quick how fast it revs from 5,000 to 7,000. I took some videos but they don't look as impressive as it feels in the car.
A friend who is very familiar with my car and has ridden in it many times was riding while I was working on the tune right after the LLSR cam went in. He decided to pull my old Cam Motion 230/238 from his LS1 and order a LLSR for himself. IIRC he didn't even change his cam specs, just got an equivilent duration and LSA but Kip maxed the lift to the limits of the springs since he is using adjustable rockers.
The only limit to the stock rocker method is the lift...too much and it can cause issues. Mine is in the .635" range. My friends is in the .670" range.
