Scratch built engine harness alternator wiring.
Old Aug 25, 2016 | 01:22 PM
JKzLBZ's Avatar
Default Scratch built engine harness alternator wiring.
Hey guys can someone please help me with a alternator wiring issue. Got a 01 5.3 put a microsquirt and my own built harness everything is runnin fine besides I cant get alternator to charge. Its a 01 145amp truck alternator. Witch plugs do I need to give power to, to get the alternator to charge? Its the four plug connector. I did some searching but couldnt find anything! any help would be appreciated
Attached Thumbnails Scratch built engine harness alternator wiring.-img_3635.jpg   Scratch built engine harness alternator wiring.-img_3636.jpg   Scratch built engine harness alternator wiring.-img_3637.jpg   Scratch built engine harness alternator wiring.-img_3634.jpg
Old Aug 25, 2016 | 09:32 PM
S10xGN's Avatar
Try this:
Attached Thumbnails Scratch built engine harness alternator wiring.-cs130d.gif
Old Aug 26, 2016 | 07:54 AM
JoeNova's Avatar
Restricted User
Run a wire with 12v ignition source to Pin B with a 470 Ohm resistor inline somewhere. That's all you need is the one wire with a resistor on it. It will charge at 14 volts.
Old Aug 26, 2016 | 09:19 AM
JKzLBZ's Avatar
Ok well heres the deal I did that 12v with 470 ohm resistor to pin B and it doesnt charge and thats a Brand new alternator. Can you ruin the alternator by supplying power to the wrong pin? because I tried b and c.
Old Aug 26, 2016 | 08:49 PM
S10xGN's Avatar
Take it by Autozone or Advance and have it checked (free).
Old Sep 3, 2016 | 11:38 AM
JKzLBZ's Avatar
Ok guys so I took my alternator to o reilys and got it tested its chargin fine there. I cant get it to charge tho! tested my wire with 470ohm resistor its good got 12vs there. Is there a chance my alternator isnt getting a good ground? Or a chance iv got a differnt alternator that needs more than just one wire going to pin B?
Old Sep 3, 2016 | 09:36 PM
S10xGN's Avatar
Looking again at your pix, it appears the main charge wire (8 gauge or so) to the battery isn't installed on the stud? The charge has gotta go somewhere...
Old Sep 3, 2016 | 11:07 PM
JKzLBZ's Avatar
Yes i know i dont have the main charge wire hooked up iv just been testing the stud with a tester shuldnt it read voltage on the stud? I just havnt hooked up a wire yet because i havnt got it to charge.
Old Sep 4, 2016 | 09:56 PM
S10xGN's Avatar
With just a VOM lead on the stud, there's no load. The charge needs to go somewhere. Trace out the heavy charge wire, hook it up, and let it charge...
Old Sep 5, 2016 | 03:05 PM
JKzLBZ's Avatar
OH man thanks so much! I didnt know that the alt needed to see a load...? I just tried that and its Charging!! This is my first build and my first swap so its been a Awesome learning experience! My next question is.... Is know theres 15volts at the stud with it running and 12v with it off. Im wondering if 15v isnt too high? That wont cook my battery or wire? Do I need a regulator? Thanks so much fro helping me out!
