Anybody run this intake?
I dont think i have seen this low profile version. Supposedly it clears f body cowls. I have a na set up that revs to 7k. Anyone have any 1st hand experience with this? It sure does look nice!
trading Massive losses in torque from 2000-5000 RPM.
I would bet 3 lb ft lost between 2-5K for each 1 HP gained
from 6000+ RPM. Best with Solid Cam peak HP 7000+
spinning 7500+ and or forced induction.
Does look cool though!
Just the opposite! The new Fast intake runners the shorter
You go the higher the Peak HP, as long as you have head flow,
Cam design, valvetrain stability, and bottom end to keep
Spinning higher.
Your version 2 would perform best with FAST 102 with standard
(long runners) for the street than change to mid length runners
For the track. Either set up would Annihilate the Sniper Intake
For your V2 Application. Ported MSD by Tony Mamo @ MMS
would also work very well. 4" Stroke makes up for RPM by
Increasing piston speed VS stock Stroke at same RPM.
