Speed Engineering True Dual Exhaust Kits!!
#521
Moderator
Received 1,838 Likes
#523
WHOA! Almost make the butt dyno black and blue....
#525
to quiet it down a bit. I cut it down into 3 peices and insert one section into each muffler.
#526
Also i put one of these muffler inserts to quiet it down a bit. I cut it down into 3 peices and insert one section into each muffler.
#527
#529
If you spend the time, you can make them fit quite well, if you slap it all together and kick it out the door youll have some fitment issue. I get the odd rub on the odd speed bump...ill spend more time on it after i do my clutch. For the savings its worth it. Also i put one of these muffler inserts
https://www.summitracing.com/parts/dtc-772-32520
How does your car sound? Did you put them in while installing or go back and do it afterwards?
#531
I'm running the same PRC heads with a TSP 233/239 cam & 92 Fast/PTM through pacesetter Lt's into a GMMG Y & putting down ~440
The TSP dumps are intolerable for any length of time, so the duals would help uncork my setup... Still, I don't think I'm going to pick up 40 hp with them... that MS3 must be where you're walking away from me.
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
#532
#533
The following users liked this post:
fucter (01-25-2021)
