Intake Manifold Flow Tests: LS1, LS6, TBSS, BBK, Dorman LS2, 102 Fast LSXRT & more
Old 05-08-2018, 04:23 PM
  #421
Moderator
Darth_V8r's Avatar
Received 1,838 Likes on 1,146 Posts
My pleasure.
Old 05-08-2018, 07:59 PM
  #422
Mr. SSinister's Avatar
Has the ported Dorman arrived from WS6Store?
Old 05-09-2018, 05:41 AM
  #423
99 Black Bird T/A's Avatar
Received 1,444 Likes on 1,002 Posts
None of the WS6 Store intakes have arrived yet.
Old 05-09-2018, 11:52 AM
  #424
Jenson's Avatar
Im ready for some more data lol
Old 05-09-2018, 02:30 PM
  #425
Jensen nicely done! Thank you adding your chart to the 1 st post
I'm hoping we can get some more data soon...
Old 05-09-2018, 03:02 PM
  #426
Jenson's Avatar
No prob...Im using your data the same way I am using head flow from companies to purchase heads (which I also have tons of data for lol). I will run the MSD with a cam eventually, but for bolt on work its gonna be the 90mm LS6 or TBSS I think. I probably need to add another row for Avg. flow from .3 and up too.
Old 05-10-2018, 10:56 AM
  #427
CBIII's Avatar
Good luck on that. I've been severely disappointed with them in every transaction I've had. I've been hoping to see something on the ported dorman truck intake also. I know I had a SOTP gain when I switched to mine over the gen3 truck intake but it wasn't dyno'd to confirm.
Old 05-12-2018, 03:51 PM
  #428
Contacted Land Speed Cylinder Heads, the shop that has done the testing previously. Tentatively we're shooting for next Saturday May 19th to test.
Old 05-13-2018, 01:02 AM
  #429
dreadpirateroberts's Avatar
interesting that the dorman ls2 flows about the same as a ported LS2.
Old 05-13-2018, 11:03 AM
  #430
Received 3,111 Likes on 2,426 Posts
Dorman's is different than the OEM LS2 manifold. I understand they used some "obsolete" FAST tooling to build theirs.
Old 05-13-2018, 01:41 PM
  #431
I would like to test an LS2 intake manifold but I don't have access to one.
That would be a nice addition to the chart. I've test a early Dorman LS2, late Dorman LS2 and a WS6 Store ported Dorman LS2 but not an actual LS2 intake manifold.
Old 05-13-2018, 02:03 PM
  #432
wannafbody's Avatar
What's interesting about the numbers is the ported Dorman LS2 flows better at lower lifts and worse at higher lifts. Kinda unexpected.
Old 05-13-2018, 03:11 PM
  #433
If it's an easy enough answer, what's the difference between the early and later Dorman LS2's?
Old 05-14-2018, 12:59 AM
  #434
ok, since you want to go there:
they used fast tooling to make the bottom and mid shells. the top is their own design, and imho it sucks.
i would rather have an "obsolete" fast 90 than a dorman ls2 or an OEM ported LS2.
now, like i said, it is interesting they flow similar. i'd rather have a ported LS2 if i had to chose between the two because it can be had for cheaper. or better yet, just have an actual FAST--which i do on both of my vehicles.
Old 05-14-2018, 01:03 AM
  #435
it would be nice.
from what i have read, the OEM LS2 manifold was actually supposed to be a superior manifold to the LS6 and was hampered, unfortunately, from the lousy 3-peice construction and poor joint sealing/matching between these molds. i can attest to that from porting a few, although i've never dynoed or flow tested. plenty of posts and threads about it from years ago, though.
had GM stuck with a lost-core casting process that they used for the ls1/ls6 manifolds, LS2 OEM manifolds might just be the coveted OEM cathedral port manifold. but, it ain't.
all the same, the design is there, even though the construction quality ruins it--plenum volume, runner length, shape, and cross section. ported, it should preform relatively well. ported ls2 manifolds to tend to gain a bit over non-ported in practice.
Old 05-14-2018, 01:07 AM
  #436
plenum and runner design is different between the two manifolds. i would expect variances like that. i think it's more interesting the flow is as close as it is.
Old 05-14-2018, 05:47 AM
  #437
That's incorrect. The ported Dorman LS2 flowed better at higher lifts. Check my post with the raw data.
Test Date confirmed for Saturday May 19th
Old 05-19-2018, 06:03 AM
  #438
On way to Land Speed Cylinder Heads to do testing this morning. My recently repaired 99 TA's Norris Motorsports 416 is getting some more break in miles today in the "truck role" of carrying parts
Intakes
Tony M ported MSD
LPE 90mm snout LS6
Super Vic
Super truck
Cylinder Heads
LPE / GMPP used previous and Wagner NASCAR LS2 799 with titanium valves. The wagers have a wing in the intake ports that I think is specifically designed for carb applications. They seem a natural to test with the Super Vic.
Old 05-19-2018, 10:37 AM
  #439
The Super Vic is AMAZING and it's specifically NOT port matched to the GMPP/ LPE heads!
Old 05-19-2018, 10:45 AM
  #440
wannafbody's Avatar
I was looking at post 424. Is that info incorrect?
Quick Reply: Intake Manifold Flow Tests: LS1, LS6, TBSS, BBK, Dorman LS2, 102 Fast LSXRT & more
