LS1 Overheating.. Bad Tstat?
Now, once the car gets up to temp it begins to overheat and the leak starts again. it looks like it is coming from the lower rad hose, could it be that my tstat is shot? not opening and the coolant is building up in the hose and spraying out?
Also, i filled the coolant back up, and the dip stick in the reservoir level has not changed at all whether the engine is hot or cold.
any ideas will help, thanks
If the car is overheating and you have put the new waterpump in properly with all gaskets and tightened down properly, its most likely the tstat being stuck.
If it is stuck the fluid wont be able to travel into the coolant jacks causing it to over flow and maybe start to leak ?
there is a quiet a few ways to check if it is stuck, when the engine gets warm feel the upper n lower hoses if they are cold.
you can also take the thermostat out and put it into boiling water to see if opens up...
I am not 100% its your tsat just giving you a trial and error..
any one else on the forum that my know what it is? correct me if I am wrong
If a hose is leaking did you make sure the clamp is past the lump around where it clamps on?
Torqued bolts correctly? Chased threads? (I always do that on aluminum parts.. Just me... )
While the radiator is out clean your condenser as well.
are way more likely than a thermostat failure. Though
you might also check that the little bubble-bleed thing
is free moving, and then "burp the baby".
Bad head gasket doesn't need the motor to be hot,
to start puking. Only needs high cylinder pressure.
And even then, coolant ought to come out the
overflow, past the radiator cap, not a hose or at
the block. But sweet white smoke, bad. If it keeps
up.
If the system can't hold pressure it will boil, perhaps
locally below the thermostat crackpoint (heads are
always hotter than coolant)..
It's basically a hand pump that goes in your radiator. Pump up the tester to 15psi and look for any coolant leaks.
A bad thermostat wouldn't cause a coolant leak. Find the leaks with the tester, fixing the leaks will fix your problems
