2 LS6 intakes, what to do???
Sell the LS6 manifolds and get the FAST.
If the price is right I will happy buy one of your LS6 intakes.
If your heads and cam package will feature a small cam that's very daily driver friendly: based on actual dyno testing done on my RS Camaro with the Fast 102 LSXRT, 92 LSX & a Peak Ported LS6 with 90mm TPiS snout, I would favor Peak Ported LS6 with 90mm TPiS snout. On my RS the trick Peak Ported LS6 with 90mm TPiS snout intake had the best area under the curve in hp & torque and also made the best peak hp & torque. It is also much easier tune to 100% stock driveability.
Note in testing on my RS the Fast LSX made 3 less peak hp than the trick LS6.
The Fast LSXRT made 2 less peak hp.
As with any build correctly matching all the parts together for the application will produce the best results. Best wishes with you build.
Fire proof flame suit on
