4.8l to TH400
What I've done:
-dropped the pan checked the filter seal and fluid all checked out
-swapped in a known loaned good transmission and torque converter same issue same whine.
What I used to adapt:
https://m.summitracing.com/parts/pio-fra-450
Could the torque converter to flexplate spec be out? Has anyone had similar issues? Thank you!
I used the flexplate that came with the motor and this adapter.
https://www.summitracing.com/parts/s...saAr8MEALw_wcB
Your converter is probably hitting the adapter.
Get a hughes adapter what I use, https://www.summitracing.com/int/parts/hup-hp3795
which is just a machined spacer that you hit into the back of your crankshaft and extends the crankshaft spigot for your TH400 converter to locate properly.
The GM adapter is too bulky. And the way it tightens on with the flexplate bolts it's not even guaranteed to have a true center point. The Hughes piece above is much simpler, lighter, and best.
