Amp draw with OEM alternator.
I'm somewhat competent in electronics but I can't find the information, at least presented in a way that is clicking. I could probably get away with smaller fans if it is going to be an issue.
I've also read that you can upgrade to a truck 145 amp alternator, if using a relocation bracket like the one sold by CBR, but I cannot find any information on what "modifications to valve cover" entails.
Thanks for reading.
I'm just curious if anyone with dual walbros and twin rad fans that are around 20 amps a piece experience any significant voltage drop that may compromise the vehicle (i.e. significant loss of fuel pressure).
The car when stock, can easily pull 60 or so amps, so you will be over drawing the system.
The large case alternator (145 amp truck alternator, careful, there is a small case truck alternator that is 105 amp, get the 145) should fit with the relocation bracket you mentioned. It's roughly and inch larger in diameter but uses the same exact mounting points and wiring that the f body alternator does, the belt should even be fine.
Thanks again for all of your input.
