achieve most HP from bolt ons
Old Nov 9, 2017 | 11:28 PM
bryan505's Avatar
Default achieve most HP from bolt ons
Hello, I'm new to the LS1 world here. Just wondering what I would need to get for bolt ons to help me achieve HP close to 400hp if possible. thanks! I have a 2000 SS Camaro with 106k miles on it.
Old Nov 10, 2017 | 06:51 AM
HCI2000SS's Avatar
Assuming you mean 400 fwhp, then full exhaust and bolts ons should do it
Old Nov 10, 2017 | 08:24 AM
big hammer's Avatar
A nice proven setup is
Peak speed ported fast 92
Ls6 MAF descreened
90 mm lid
1-7/8 headers
Speed engineering x pipe duals
Tune
This will get you into the 365-370 rwhp range through an M6
Old Nov 10, 2017 | 10:45 AM
big hammer's Avatar
You can get over 400 rwhp with bolt ons but it takes more work
Old Nov 10, 2017 | 12:56 PM
Darth_V8r's Avatar
Moderator
Yup. Question is how far you are willing to go
Old Nov 10, 2017 | 02:53 PM
00pooterSS's Avatar
Whats the list?
Your list above is great but to get 30-40 more.. out of bolt ons..? (I feel like i'm missing something obvious). I know it would be something accessory drive related like underdrive/electric water pump/no belt at all lol. But what else am I missing here.
Old Nov 10, 2017 | 03:16 PM
Darth_V8r's Avatar
Moderator
EWP is one. Manual Steering. If you have a manual transmission a lighter clutch and smaller diameter clutch, going to fast102 vs fast92. From air filter to throttle, make that whole tract 4†and smooth. UDP.
This one can be contentious. In the small block days we used to consider higher ratio rockers bolt on. Now people see it as a poor-man cam, although the rockers cost more than the cam. Go figure. Even roller tip vs stock is helpful, because stock rocker ratio varies. You gain low lift duration with rollers.
That is probably not everything, but that will get you a good bit more. Most people will not do that list though, because a cam is cheaper than a EWP or a manual steering rack, etc.
Old Nov 10, 2017 | 05:35 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
Carbon Fiber Driveshaft, Pricey but effective.
Lighter Ring & Pinion & Diff, if available, lighter wheels &
Tires. (Soon to find out if micro-polish trans &
Ring & Pinion is worth anything)
Old Nov 10, 2017 | 06:19 PM
big hammer's Avatar
Improved racing crank scraper helps too.
Old Nov 10, 2017 | 06:22 PM
big hammer's Avatar
I got 430+ rwhp out of a bolt on ls1. It's an expensive way to get the power but then when you do go to a cam and heads you're making lots of power
Old Nov 10, 2017 | 07:14 PM
Darth_V8r's Avatar
Moderator
Forgot that one. Knew there was something. Vacuum pump too.
But when you add all that up, most will say just go heads/cam. There is something nice about a motor that has not been opened up though. Never quite seem as tight as from the factory
Old Nov 11, 2017 | 10:23 AM
wannafbody's Avatar
I'd consider heads to be bolt on.
Old Nov 11, 2017 | 10:58 AM
99 Black Bird T/A's Avatar
Definition of bolt on can be a gray area for sure.
Superchargers bolt on right?
Like Darth mentioned in the small block Chevy days rockers would usually be viewed as a bolt on. That's the way I think of bolt on 's.
Occasionally, someone would argue if engine oil touched and lubricated the part it's not really a bolt on its an internal engine Mod. In that view rockers aren't really bolt on.
If it involves more than removing the valve covers and oil touches then it's well beyond what I think of as a bolt on. Heads or supercharger are definitely not a bolt on to my way of thinking.
Do the older LS1's with the bigger factory cam tend to be better for bolt on hp than the latter 01-02 cars?
Old Nov 11, 2017 | 11:57 AM
Darth_V8r's Avatar
Moderator
Lol. Nitrous kits bolt right on too!!
I tend to include rockers as bolt on. Intake, exhaust, accessories, etc.
Old Nov 11, 2017 | 12:09 PM
SlasherVRGR's Avatar
As a guy with an older ls1 with full bolt ons and 243s I wonder this all the time.
Old Nov 11, 2017 | 01:10 PM
sxc Z28's Avatar
400 wheel is doable but not easy.
To be bolt-ons only the vehicle must be stock internals and NA. 98-00 cars do have a bigger stock cam but the 01-02 cars offset it with better 241 heads. Some 00 cars have both the bigger cam and 241s.
Rockers are the grey area. Personally, I don't care either way but it needs to be general consensus. That's the only reason I haven't done them. I'm sure some the the guys on the fast list have them but they don't allow them anymore which is a disadvantage.
Old Nov 11, 2017 | 01:52 PM
dreadpirateroberts's Avatar
400 wheel is doable in an LS2 or LS3.
LS1, i can't see it unless it's a generous dyno.
Ls6 MAF descreened
90 mm lid
1-7/8 headers
Tune
with what stock cam? i know quite a few of the f-body guys can hit 360+ bolt on...
Old Nov 11, 2017 | 07:42 PM
big hammer's Avatar
The earlier cam. Which is worth 5-8 rwhp over the later LQ4 cam
Old Nov 11, 2017 | 07:48 PM
big hammer's Avatar
LT1 and old 5.0 guys considered rockers bolt ons. Some guys don't. Not really a big deal. They're easy to install and so help a little
